Problems locking a Givi 340 to its rack
HanzoKarai
PostPosted: 23:19 - 15 Jan 2019    Post subject: Problems locking a Givi 340 to its rack Reply with quote
Can anyone help? I bought a yamaha ybr custom from someone on gumtree, absolutely no problem with the bike itself but the givi 340 monolock topbox that came with the bike is giving me hassle as far as locking it to its plate goes. The box itself locks fine but I can't seem to be able to lock the box to the rack/bike!!😣😣😣
mentalboy
PostPosted: 02:44 - 16 Jan 2019    Post subject: Reply with quote
Is it a monolock rack?
Does the locking mechanism on the bottom of the box move freely, WD40 or similar will help free it up if it's stiff.
What condition is the locking stub on the rack?
Those are the only three things that affect the locking action on the monolock system, if it's any consolation mine was always tight and needed a good slam.
Make mine a Corona.
HanzoKarai
PostPosted: 02:57 - 16 Jan 2019    Post subject: Reply with quote
It is indeed!! Part way through fixing the issue now tho!! So I’d checked a few forums and none of the suggested solutions I found worked, (the box clicks into place but didn’t lock to rack when box was locked closed) so in the end I dismantled the locking mechanism and found that the button that locks box to rack was broken!!! (A tiny piece of plastic that fits into a slot thus stopping the box from being removed from bike) I dug out my epoxy and have put it back together!! Hopefully once it’s fully cured and sanded down a little all will be well!!!
Thanks a bunch for the speedy response tho bud!!Wink happy riding!!
Hanzo.
iooi
PostPosted: 20:56 - 16 Jan 2019    Post subject: Reply with quote
A hint. If that has happened. Be aware it may well fail while you are moving....
quite funny watching a top box grind its way down the road.....
Get a couple of bolts and get it solidly fixed
HanzoKarai
PostPosted: 21:11 - 16 Jan 2019    Post subject: Reply with quote
Yeah I thought that may happen, so I’ve ordered a new box. To be fair though if it does fail, it shouldn’t come off the bike, the part that broke is the latch that locks the box to the bike so it can’t be removed without the key. The mechanism that allows the box to be slotted into the rack is actually ok, was literally the lock that was broke so hopefully that won’t be a problem!!! Though in retrospect if someone wanted to steal the box it would probably only take a good strong push or a good tap with a hammer I suspect to break the mechanism...... will probably just swap the box out wen new one comes!!Wink
The last post was made 7 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.25 - MySQL Queries: 14 - Page Size: 43.73 Kb
