Motorbike Storage
Vealester
PostPosted: 18:17 - 17 Jan 2019    Post subject: Motorbike Storage Reply with quote
About to purchase a new Lexmoto lxr 125
Im wondering what kind of shed and size i should buy to store it
Also the best anti theft devices!
Tankie
PostPosted: 18:21 - 17 Jan 2019    Post subject: Reply with quote
You have the basic choice of Metal, brick or wood.
Metal sweats
brick, a bit permanent
wood non permanent structure, which will fill most of your needs
PostPosted: 18:25 - 17 Jan 2019    Post subject: Reply with quote
Where are you in the country? I ask because different places have different amounts of problems with #bikelife stealing anything that's got two wheels. Crying or Very sad
The best anti theft device is a more desirable bike that's got very poor security parked right next to your bike when your bike is locked up with a big old Almax chain. Thumbs Up
Vealester
PostPosted: 18:28 - 17 Jan 2019    Post subject: Reply with quote
Scotland, not really a crime ridden area, couple riders in my street but i seen they all have storage for theyre bike
NJD
PostPosted: 18:35 - 17 Jan 2019    Post subject: Reply with quote
Vealester wrote:
Scotland
Depends where though, right? Unfortunately our resident Scotsman has vanished off the face of the earth, but I might be missing another member who knows more about that area than I do. Glasgow, for example, seems to be reported as high on crime.
On a small bike I'd say a 13 mm pragmasis for out and about and a 16 mm for at home, or a 19 mm if you can fit the links through the underside frame grab rail (if it has one). I wouldn't have carried anything heavier than a 13 mm on my 125 simply because it was too under powered as it was, and that too was a Lexmoto.
For a 125 you'd only really need the smallest of spaces, the Lexmoto website should give you the specs and so you can work around that. Of course it then depends if you'd also want to work on the bike in that shed or not, and then you'd need something more. Depends on how much space you've got and if the ground is level.
Always secure it to something, so plan your shed with a ground anchor. Secure it to something when out and about and put a chain through the rear wheel and underside grab rail if you can't, with the bike on a centre stand (if it has one); or over the seat and through the wheel on the stand.
Disc lock on the rear and front, anyone can pick up the front of a 125 and wheel it off or into a van etc because they're so lightweight.
PostPosted: 18:36 - 17 Jan 2019    Post subject: Reply with quote
Your options are brick built garage if your budget allows or a wooden shed if it doesn't.
PUt a ground anchor into the concrete base so you can get a 19mm+ Almax chain or Prgmasis Chain with a Squire lock.
If you rent the property rather than own it then your options are more limited.
What do your neighbours use for storing their bikes?
kgm
PostPosted: 19:44 - 17 Jan 2019    Post subject: Reply with quote
There aren't too many issues with bike thefts in Glasgow or many other areas of Scotland. It happens, but it's not a high level. Edinburgh is the main exception, bikes get plundered there. There are more issues with car theft in Glasgow and Lanarkshire by but even then it's not horrific. Violent crime is the biggest issue with Glasgow.
Vealester
PostPosted: 21:35 - 17 Jan 2019    Post subject: Reply with quote
I live in fife, cowdenbeath area. My neighbors use a brick garage and one uses just the shed. The property is rented so i cant concrete in a lock.
It's only to store the bike, not work on it.
Riejufixing
PostPosted: 22:57 - 17 Jan 2019    Post subject: Reply with quote
Then you want a roof, not a shed. Keeping a wet bike in a shed is not very good for it.
The last post was made 5 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 17 - Page Size: 61.71 Kb
