Out and about chain
bigdom86
PostPosted: 23:11 - 11 Feb 2019    Post subject: Out and about chain Reply with quote
Hi all, in the market for a new chain. I have an almax at work and at home but looking for an out and about chain as i am using my bike i bit more for day to day travel, gym etc. Would the pragmasis 16mm 2m noose option with the ss65c stronghold lock be too heavy in your opinion to carry about in a tailbag on the cbr6? I like the idea of the noose as saves space and 16mm as can resist croppers
NJD
PostPosted: 23:30 - 11 Feb 2019    Post subject: Reply with quote
Kriega US-20 can handle a 2.0 m 16 mm on a regular basis without struggle, and is probably about the only thing that will (Kriega, that is: you could probably fit it in a 10, but don't hold me to that).
You'll feel a difference in handling etc but nothing that will cause a large amount of trouble, or that can't be adjusted to.
Tie it down firmly each and every time and you'll be ok, and if you don't you'll know about it.
Pack the bottom of the Kriega with a couple of old sweatshirts; doing so means you'll get a firm ratchet rather than a disfigured on on your oddly shaped luggage (towels, tops etc: anything bulky that can fill the bottom out).
PostPosted: 23:35 - 11 Feb 2019    Post subject: Reply with quote
It's no big deal if you think about it compared to the weight of carrying a pillion passenger.
ThunderGuts
PostPosted: 09:18 - 12 Feb 2019    Post subject: Reply with quote
I carry an Oxford Monster 14mm 1.5m chain regularly in my US-20 tailpack on my ER5. The chain weighs about 7kg including the lock, plus a Monster disclock for the front, so probably about 7.5kg all in.
I notice the extra weight when moving the bike around by hand (e.g. getting out of the garage, getting it in place to lock it up etc.) but I'm not conscious of it when I'm on the bike (maybe I'm used to it?). I think it's noticeable when moving the bike about because the weight is quite high up but once I'm on it the weight becomes fairly insignificant.
Do you need a 2.0m chain? I frequently find my 1.5m chain is actually too long and I have to be inventive to get rid of the excess chain when locking it up so it doesn't sit on the ground (I'm wary of sledgehammer attacks).
If you do go down this route, I'd suggest getting a square of foam camping mat (the old Karrimat type stuff) and putting it inside your tailpack, then make sure it sits with the foam between the chain and the seat otherwise your chain can put nice dents into your seat when you tighten the straps down (mine seem to lift out gradually, but it's not a bike I'm mega precious about).
TG.
bigdom86
PostPosted: 15:09 - 12 Feb 2019    Post subject: re Reply with quote
cheers all, I think the 1.5m should do the job tbh as I am going for the noose option (does anyone have this type of chain? - i wonder why I don't see more about as it seems a very good idea!).
I will keep a towel and my gym clothes in the bag too so that will pad it out a bit
The last post was made 5 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.7 - MySQL Queries: 17 - Page Size: 45.4 Kb
