Haydl3 |
Haydl3 Derestricted Danger
Nobby the Bastard |
Haydl3 |
Haydl3 |
kawakid |
kawakid World Chat Champion
Haydl3 |
WD Forte |
WD Forte World Chat Champion
Haydl3 |
Haydl3 |
kawakid |
Haydl3 |
sickpup |
sickpup Old Timer
Haydl3 |
Hong Kong Phooey |
Posted: 16:59 - 18 Feb 2019 Post subject: |
Switched relay all day. Even without a device plugged in there is parasitic draw, I fitted one direct to battery and a week later flat battery.
I tested and didn't detect any drain but my meter isn't that good.
Have a ganders at Stinkers excellent write up.
https://www.bikechatforums.com/viewtopic.php?t=192684 ____________________
Haydl3 |
kawakid |
Posted: 22:53 - 18 Feb 2019 Post subject: |
Haydl3 |
Haydl3 |
Meatybeaty |
Meatybeaty World Chat Champion
A100man |
A100man World Chat Champion
Posted: 16:04 - 20 Feb 2019 Post subject: |
Fuses are to protect the wiring in case the 'appliance' goes faulty. Use a fuse value somewhat below the rating of your chosen cable.
These chargers appear to be able to source up to 2A @5v so I guess only really need a 1A feed cable at 12V but sure, add some margin. Really not sure why you include any relay for this, just a switch to isolate in case there is some 'passive' current drain. Relays are mainly used to switch high loads via a low current rated switch.
Edit - OK I understand having read Stinkwheel's guide that using an switched live from the ignition to 'fire' the relay is helpful as you don't have to remember to turn off the'appliance' to save the battery. ____________________ Now: A100, GT250A, XJ598, FZ750
Haydl3 |
The last post was made 5 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
