stevo as b4 |
redeem ouzzer |
stevo as b4 |
Tankie |
Tankie Crazy Courier
Sister Sledge |
- Super Spammer
Posted: 09:50 - 22 Feb 2019 Post subject: |
When I raced in the YPM, we had a batch of Mitaka pistons which were slightly over the stated size, making clearance a bit tight and leading to a lot of seizures. It seems Mitaka started making pistons in Japan and somewhere else, the dodgy batch came from their non Japanese factory.
You really could do with checking clearance accurately or maybe whilst it's in bits, but a better quality piston in, if the bore is definitely in spec. Someone like Grampian Engineering will inspect the bore size, correct if needed and supply a piston and ring kit for not a lot of money.
That'd be my guess anyway. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
bikenut |
bikenut World Chat Champion
Old Git Racing |
Old Git Racing World Chat Champion
rs700 |
rs700 Derestricted Danger
steve the grease |
stevo as b4 |
Posted: 20:14 - 27 Feb 2019 Post subject: |
https://i.postimg.cc/fJVmJ6Nv/DSC-1512.jpg
https://i.postimg.cc/0M5Jx4nD/DSC-1511.jpg
https://i.postimg.cc/18xn4XM9/DSC-1517.jpg
Here's the pictures, they don't show up the seizure marks that well, but yeah it's a classic 4 corner seizure, inlet size worse than the hotter exhaust side.
Ive never had a bike show this kind of seizure before, so that's why I was curious as to what's causing it?
In my mind it had to be a clearance issue, or a lubrication issue. As I said it was run in on pre-mix at 36-40:1, and it was babied by myself, kept under 1/2 throttle and under 6000rpm for 250-300 miles, followed immediately by a dyno run.
The oil used was Silkolene Comp2 plus. Its a fully synthetic oil, but not a full on race or MX oil like Pro2 or MX2 etc. I changed the plug from a BR8 ES to a BR9 ES and I ran it on 97 Ron fuel.
Its all immaterial now as I've removed the nasty linered cylinder and I've already fitted my new Nicasil cylinder and forged Wossner piston. The seized piston is a cast TKR piston probably OEM or a pattern one.
Apart from the seizure marks there no visible wear or damage to the skirt and you can see the machined finish, and the rings are free in the lands and look like new. Therefore I don't think it overheated or was running weak? But my fueling was actually weak on the pilot jet as far as I can see from my dyno graph.
I don't buy the running it in on cheap oil, as race bikes and MX bikes don't use crap oil for running in, and they are run in after an hour or two from first start up generally.
Im changing loads of things all at once on the re-build and the compression is going to be a bit higher too, so I just want it not to happen again. My optimimism says they new parts are better clearanced and getting rid of the shitty liner will make everything ok? |
stevo as b4 |
- Super Spammer
stevo as b4 |
Tankie |
The last post was made 5 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
