Honda CBR125 Electrical Problem
GrimmsterMuse...
PostPosted: 20:47 - 24 Feb 2019    Post subject: Honda CBR125 Electrical Problem Reply with quote
Hi,
I'm having a rather odd issue with my indicators on my 2005 Honda CBR 125. The indicators work fine on idle, but stop working completely after 4k revs. I have changed my relay, checked battery voltage and voltage coming from the indicators and both are fine. I have also tested to see if another relay works on my bike (from my friend's CBR 125) and the opposite happens - the indicators do not work properly on idle (they do not flash, the lights stay on) but after 4k revs, they do work normally.
Does anyone have any suggestions on what this could be before I take it to a garage?
Many thanks.
Tankie
PostPosted: 22:33 - 24 Feb 2019    Post subject: Reply with quote
Sounds like an earth fault on the bike, check the earths in the four bulbs
diadingo
PostPosted: 16:14 - 05 Mar 2019    Post subject: Reply with quote
Are you using LED tirn lights? In that case make sure relay is for LED also
F18
PostPosted: 17:31 - 05 Mar 2019    Post subject: Reply with quote
I'd be measuring the battery/system voltages at different revs. You may find your charging system is out of spec beyond 4k revs (either way, too low or too high).
Easy to test - if only to eliminate some basics.
This assumes the indicators on your bike are running off the main battery supply, else all bets are off (well, move to a mag coil).
Summer is just around the corner
The last post was made 6 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 14 - Page Size: 38.22 Kb
