Easy-X |
Easy-X Super Spammer
Posted: 00:19 - 09 Mar 2019 Post subject: Rough spots in rev range when cold (EFI) - FIXED |
Hey guys,
Long time lurker on these forums but I'd really appreciate some advice. Give me a moment while I don my flame-retardant jump suit...
I have a Keeway Superlight 125 and yes, I know how well you guys love cheap Chinese bikes Anyhoo, I bought it nice and cheap and have almost got it back to good running order but I still have one minor annoyance.
From cold it starts perfectly but once I get around the 3000 rpm mark it bogs a little bit. Get over 5000 and it's fine. Takes about 5 mins to warm up and then it's great through the entire rev range. (Note, this is the engine under load, it's not noticeable when in neutral.)
TBH it's not a major problem as the first mile of my commute is all 20mph suburban rat runs anyway so by the time I can get to its cruising speed of <cough> 30mph the engine's fine!
Sensible things I have done:
Cleaned the air box, replaced the filter and checked for leaks
Replaced the spark plug, gap'd to manufacturer's spec
Oil change, 10W40 Castrol racing oil (racing?! wtf was I thinking!)
Adjusted the path of the throttle cable (previous route was a little "sticky")
Replaced the handlebar throttle (again, original didn't turn as smoothly as i would like)
Checked ECU for errors (none logged)
Sensible things I haven't yet got around to:
Check the valve gaps (where are my feeler gauges? I had them for the spark plug...)
Check the throttle is *actually* turning smoothly after sorting the other throttle/cable issues
Replacing the fuel filter (haven't actually found it on the parts diagram)
Do a data log of whatever the ECU can give my Torque app
Insane things I haven't considered doing:
Strip down the throttle body (my mechanic mate said leave it alone)
Pull the fuel injector and examine/clean/replace (seems extreme)
Piled a load of so-called "injector cleaner" into the tank
So, suggestions other than "buy a Yamaha" would be appreciated ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter
Nobby the Bastard |
Easy-X |
Posted: 00:33 - 09 Mar 2019 Post subject: |
TBH I only did a close visual inspection when I had it out to clean but thanks for the WD40 tip, I shall add that to the check list.
Hehe, I'm already expecting to change the oil a lot. I got this to learn on and, so far it's been - how shall we say - as entertaining as expected ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Robby |
Robby Dirty Old Man
stevo as b4 |
Easy-X |
stevo as b4 |
Baffler186 |
Baffler186 World Chat Champion
linuxyeti |
linuxyeti World Chat Champion
Easy-X |
Posted: 17:17 - 11 Mar 2019 Post subject: |
Dammit! I've been sold a lie: EFI is meant to be sooooo much better than carb, especially when it comes to cold starts ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Robby |
Robby Dirty Old Man
linuxyeti |
Posted: 20:41 - 11 Mar 2019 Post subject: |
Nothing wrong with chinese bikes, if looked after. At least they don't keep randomly cutting out, usually when slowing down off slip roads or roundabouts, which my Triump America hada very good habit of doing !!
The weather has been pretty nippy, so, just let the bike warm up for a minute or 2, leave it ticking over whilst you put your helmet & gloves on. Read up on quite a few efi bikes stalling etc, can't remember which forum it was now though that suggested allowing an efi engine to warm up, and that seems to pretty much completely cure the issue.
Pretty sure that came from a Yamaha forum. ____________________ Beware what photos you upload, or link to on here, especially if you have family members on them |
WD Forte |
WD Forte World Chat Champion
Easy-X |
Posted: 01:14 - 13 Mar 2019 Post subject: |
Interesting... last time I checked the battery it was 13.something volts so I assumed that would be okay.
I have a new one kicking about (that I just use for testing bulbs!) I might swap it over this weekend if the bike hasn't blown away in the gales ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
EazyDuz |
EazyDuz World Chat Champion
Easy-X |
P. |
P. Red Rocket
jaffa90 |
jaffa90 World Chat Champion
Easy-X |
jaffa90 |
talkToTheHat |
talkToTheHat World Chat Champion
Easy-X |
Posted: 03:56 - 16 Mar 2019 Post subject: |
talkToTheHat wrote: | Hold on, your problem is "Bike has a bit of a hiccup at 3000 rpm when it's cold, but is fine over that" ???
Now, maybe I'm an old fashioned sourpuss here, but every bike I've owend warned me not to take it over 4000 rpm until warm and were varius kinds of unridable untill they'd had 30 seconds to 2 mins on choke warming up and none of them got the beans untill they responded normally to the throttle with the choke off.
Cars don't run smooth cold either. You're not advised to sit idling to warm up any more becasue emissions, but seriously, just because you have EFI cleverness doesn't mean it's a good idea to thrash the nuts off the bike before its warm. |
Point well made, consider me (very slightly) more educated about bikes ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Easy-X |
Tankie |
Tankie Crazy Courier
The last post was made 5 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
