Mr Hammers |
Mr Hammers World Chat Champion
Posted: 21:07 - 11 Mar 2019 Post subject: Any exhaust specialists that can advise...? |
So, i bought new cans for the Triple, and posted about them here.
Now, as good as they look, and as good as they sound, they are unbearably loud, even with the baffles in.
I called SP Engineering today and spoke about it with a woman there. She said in the past others having the same issue tried blocking the holes around the main outlet pipe. So when i got home, i did just that;
https://www.planetash.net/bcf/cans/triplebaffles.jpg
Double nutted the bolts and peened the ends so i don't end up having to remove the main pipe if a nut comes off. It is slightly quieter now, but still too loud for my liking.
https://www.planetash.net/bcf/cans/triplebafflesend.jpg
So, i was thinking about modifying the existing baffle to try and dampen down the noise a bit, or at least take the 'crack' out of it.
I know virtually nothing about cans and the physics of them, but i was wondering if something like this would work in bringing the volume somewhere between these cans and the stock ones.
A is the baffle, B is baffle packing, and C is a round plate that would be welded to the end of the baffle tube.
https://www.planetash.net/bcf/cans/triplecanplate.jpg
I did try some baffle packing in them left over from another job, and it seemed to dampen it quite well, but that was just temporarily wrapped around the tube and shoved in. Obviously during normal riding it would just end up working it's way down into the cans without a plate and/or some wire or mesh around the packing to hold it in place.
I don't mind losing the supposed bhp gains they bring, if it means i don't wake up half the neighbourhood every morning at 7am.
My question is: would this be a good way to do it, or is there another way? Like extending or shortening the baffle tube, and/or drilling holes in it then wrapping in baffle packing to disperse the sound..?
Hoping someone who knows the ways of these things can give us some helpful advice.
Cheers! ____________________ A Guide To Powerbands |
Fisty |
Fisty Super Spammer
Mr Hammers |
Sister Sledge |
Mr Hammers |
Posted: 22:51 - 11 Mar 2019 Post subject: |
No. The XLS versions are, they're about 50mm longer. I would've gone for those but they stick out beyond the tail light and look a bit daft. ____________________ A Guide To Powerbands |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 23:03 - 11 Mar 2019 Post subject: |
Not the best design. What you want, and I did myself, is a pipe with closed of end and holes drilled into the pipe along side. That way the ''noise'' has to travel further distance and bounce of the inner pipe before it gets through those holes and out back. With the pipe fully open the noise reduction is negligible, unless that is what you want to achieve, stupidly loud let appearing road legal at the same time.
Like so,
https://www.megalevnepneu.cz/fotomp/783.18.37.jpg
https://img.skutry-levne.cz/41d48e526f04e6b742c5b4e32b09b17ef1a53098/thickbox/vlozka-db-killer-turbo-kit-maxi-skutr.jpg ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Posted: 23:12 - 11 Mar 2019 Post subject: |
You could try sticking another (minimalist and fairly wide) removable baffle in from the other end. So the ends of the two baffles overlap. Then you'll have a kind of z-flow effect.
In fairness, the "baffle" seems very straight meaning the gas is probably passing right through the end can and out of the end without slowing down in the middle to expand. Any effective silencer baffles I've seen have a bit of a dog-leg in them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Robby |
Robby Dirty Old Man
MarJay |
MarJay But it's British!
pig hog |
pig hog Scooby Slapper
MarJay |
RhynoCZ |
Posted: 15:17 - 12 Mar 2019 Post subject: |
Robby wrote: | Making baffles that work at home is a fairly involved process, lots of trial and error. I only did it because no-one currently makes quiet silencers for one of my bikes. |
The ''my design'' was about making the holes bigger and bigger (reducing the restriction), as I was testing the motorcycle on the open road. In the end, I got it quite alright. It was a carbureted GPz550 and I have not touched the jets. The final result was pretty much:
Db killer in = very strong low to mid range (nice to ride in town), the top of the rev range felt like ''empty revs'', no need for ear plugs, no louder than average motorcycles.
Db killer out = quite the opposite, nothing at the bottom of the rev range, it felt like all of the torque started just 1000 rpm before the rev limiter, EAR PLUGS REQUIRED!
*worth mentioning the exhaust system had no silencers. I used to enjoy such things.
EDIT: I also made it small enough, so it would fit under the seat of the GPz. I usually started without it (to start the engine, I pushed the bike one street over, so I don't annoy my neighbours), having blast and all that and when that got tiring, I popped it in and rode home quietly. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
redeem ouzzer |
MarJay |
RhynoCZ |
Bhud |
Bhud World Chat Champion
stevo as b4 |
stevo as b4 |
Posted: 20:39 - 12 Mar 2019 Post subject: |
If all else fails you could always fit a turbo, as that'll take a load of sound energy out of the exhaust system, and probably make it a bit quieter than std at low Revs. |
recman |
recman World Chat Champion
biker7 |
biker7 Crazy Courier
Mr Hammers |
Posted: 00:22 - 13 Mar 2019 Post subject: |
Cheers for all the input guys, much appreciated.
Well, the ride with the holes plugged this morning was a lot more civilised. Made a bigger difference than i'd expected. Also gave me hope for taking a bit more of the edge off the sound level by way of modding the baffle. Using the sound app on the phone, the sound levels (after plugging the holes) are down to about 80 when idling, and rising to 100 when revving the balls off it. If i can get it down to around the low 90s i'll be happy.
Got a week off next week, so i think i'll experiment with various baffle types and placement, in fact quite looking forward to it as it could be quite interesting.
recman wrote: | I think my carbon XLS look good.
I also went for them rather than the stubbys because having viewed a few YouTube videos, I knew they'd be too loud. |
Yeah, ignore me, i've always had a bit of a thing about long cans, it's a pet hate. If you're happy though, i'm happy
I did do some research, but i found it impossible to gauge just how loud via youtube vids. Even filming mine before i put the cans on (just straight through pipe) really gives no indication at all of the hellish, ear splitting noise they made. And by christ was it loud!
Stevo:
You're right, if you're going to have smaller cans be prepared for the extra noise...but i'm looking at it like this: the stock cans have to pass the rules so stifle the engine to keep the noise down. I'm prepared for a higher sound level, but not as loud as they are/were. Ideally i'd like somewhere in between the extremes of stock and stubbys. I think i could do that with a bit of trial and error modding the baffle (or even making some from scratch). I'm hoping that as the stocks are so restrictive, that restricting the stubbys to get to the level i'd like, will still be less restrictive than the stocks. If i can't, then so be it, but it'll still be fun trying
Hmmm...turbo....that's an interesting thought! But...no. Don't think i want to go down that route..at least not on the triple. Think i'll save that one for when i do my project Bandit
If/when i do get to where i want to get, i'm going to take it down to the local dyno and make sure it's all set up for it. No point in doing that until i've done it, of course.
RhynoCZ:
Yes, that's what i was thinking (blocked up end with perforations in the tube). Also thinking about various plates in different sizes and shapes. The great thing about removable baffles (and they're really easy on the SPE's) is i can whip them in and out and instantly see, or rather hear, the effect.
GT200Fan79:
Interesting, goes to show there's more to it than you'd think. Could it also be that the bike was setup better for the stocks than the straight through can?
Incidentally, i didn't notice any lack of power after putting them on with the baffles in. It still reached 143 (on a private road of course!) as it did with the stocks. How the midrange and lower end changed, if at all, was difficult to determine, as in it seemed to feel the same.
Marjay:
Yes, they do look loud, but as i mentioned before, all the vids i watched beforehand didn't really convey just HOW loud they'd be. It's not until you're stood next to them IRL at 7am do you realise the actual volume. And i don't mind a bit of extra volume, it's nice to actually hear and feel what the engine's doing more accurately than with the stocks, that are imho, way way too quiet. And even baffled, they still sound deliciously good!
Robby:
Very true, i've been reading up on the art of exhausts and you've pretty much nailed what are the important determining factors. I, like you, will attempt to make my own by trying different solutions. If i can get a sensible compromise between sound and volume, it'll be down to the dyno to set them properly.
Stinkwheel:
Again, that's my thinking too. There's not really a lot of space in there, but the extra baffle would overcome that if done in that particular way. And yes, it is a straight through can btw, it's only the packing around the inner tube that was soaking up the sound. But as said before, i think i'll try different approaches next week, but that is definitely one of them that has promise.
Cheers for all the replies guys. Given me plenty to think about!
I'll let you all know how i get on....or if i end up putting the stocks back on......
Edit:
Bhud:
Yeah, after a lot of reading i'm now more up on the whole valve and pulse thing, and how that can affect where the power lies on the rev range and so on, so certainly something to bear in mind. But i'm still not totally convinced the stock cans are the best option. They will of course be tuned to suit the engine, but they're designed to keep the noise at (well below, imo) acceptable levels to pass tests.
pig hog:
It's not just about me hearing the noise. If i were just me on this planet the baffles would be out all the time, except on long journeys when i look for other survivors. ____________________ A Guide To Powerbands
Tdibs |
Tdibs Traffic Copper
Posted: 18:12 - 13 Mar 2019 Post subject: |
Cant claim any useful knowledge on the subject, but having used a couple, I found this design the most effective and quieting down the can enough to not be obnoxious.
https://www.ducatiforum.co.uk/attachments/duc-scorpion-baffles-jpg.47197/
So something like welding a cap on the end and perforating the tube.
https://puu.sh/CZqtt.jpg
Then most likely take it for a remap. ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
recman |
Mr Hammers |
Posted: 23:20 - 13 Mar 2019 Post subject: |
recman wrote: | All good fella, aesthetics are subjective.
I might give your nut and bolt solution a try, although I don't find the sound of my cans unbearable, having riden with fairly quiet original cans for the past six years, it wouldn't be entirely a bad idea to turn them down a bit. |
Cool Yes, surprisingly it really made a difference, more than i'd hoped. That reverberating drone in my head tootling along at 50 has disappeared almost completely. Still noisy of course, but certainly not unbearable anymore, and i don't need earplugs. I really think i can turn it down even more experimenting with the baffle too. Can't wait to get started on it!
Just make sure the nuts can't come off, or you'll have to turn the bike upside down to get them out
Tdibs wrote: | like welding a cap on the end and perforating the tube. |
Cheers, Tdibs, yes that's strategy number 2 on my list of solutions to try. First being baffle packing, held in place with an ss mesh washer, and if it's still too loud, then capping and drilling will be next. ____________________ A Guide To Powerbands |
recman |
The last post was made 5 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
