Excel VB Help
PostPosted: 12:58 - 14 Mar 2019    Post subject: Excel VB Help Reply with quote
Hi all I've never touched this before, I have tried watching/reading a few tutorials and I haven't managed to get my head round it. I want to output the result to a text file
Here is the whole Script
Code:
Sub User_Creation_Ldf()
Dim Last_Row As Long
Dim Row_counter As Integer
Dim Col_counter As Integer
    Application.ScreenUpdating = False
    Sheets("Final").Activate
    Range(Range("B1"), Range("B65000")).ClearContents
    Sheets("User_List").Activate
    Last_Row = Cells(Rows.Count, 1).End(xlUp).Row
    For Row_counter = 1 To Last_Row
        Sheets("Template").Activate
        Range(Range("A1"), Range("A2000")).ClearContents
        Cells(Row_counter, 1).Copy
        Sheets("Template").Range("A1").PasteSpecial xlPasteValues
        Cells(Row_counter, 2).Copy
        Sheets("Template").Range("A2").PasteSpecial xlPasteValues
        Cells(Row_counter, 3).Copy
        Sheets("Template").Range("A3").PasteSpecial xlPasteValues
        Cells(Row_counter, 4).Copy
        Sheets("Template").Range("A4").PasteSpecial xlPasteValues
        Call Create_Final
        Call CreateTXT
    Next Row_counter
End Sub
Public Sub Create_Final()
Dim LastRow As Long
Dim Copy_Counter As Integer
    Copy_Counter = 30
    Range(Range("C1"), Range("C" & Copy_Counter)).Copy
    LastRow = Cells(Rows.Count, 2).End(xlUp).Row
    If LastRow = 1 Then
        LastRow = LastRow + 1
    Else
        LastRow = LastRow + 2
    End If
    Cells(LastRow, 2).PasteSpecial xlPasteValues
End Sub
Sub CreateTXT()
Dim LastRow, FileNumber As Integer
Filename = "C:\folder\user.txt"
FileNumber = FreeFile
[b]Open Filename For Output As FileNumber[/b]
For i = 1 To LastRow
sLine = sLine & Cells(i, B).Value
Print #FileNumber, sLine
sLine = ""
Next i
Close #FileNumber
MsgBox "Script Created"
End Sub
This is what I have at the moment.
I have writen the CreateTXT part, TBH I have no idea what I'm doing. Laughing
The original script (everything without CreateTXT.)
Would read variables on a sheet, and use them to generate scripts and copy that to a different sheet from which a user would copy it to a txt file. I want to create this file when the button is pressed. Output is 1 column.
Debug is kicking off about the bold line. Can anyone help and explain it to me please?
Thanks,
Chris
PostPosted: 15:47 - 14 Mar 2019    Post subject: Reply with quote
[edoit] Scrap that, FreeFile is a function, not a variable Smile
Hawkeye1250FA
PostPosted: 14:36 - 18 Mar 2019    Post subject: Reply with quote
Does it need dynamic file numbering?
If not then simplify it by changing the ".. for output as file number"
To
"... For output as #1"
Then this line :
"PRINT #filenumber, SlIne"
Changes to
"WRITE #1,SLINE"
and
"Close #filenumber"
Changes to
"Close #1"
Edit: #bluepeter
Code:
Sub CreateTXT()
Open Filename For Output As #1
sLine = sLine & Cells(i, 2).Value
Write #1, sLine
sLine = ""
Next i
Close #1
End Sub
PostPosted: 11:30 - 19 Mar 2019    Post subject: Reply with quote
To
Then this line :
Changes to
"WRITE #1,SLINE"
and
"Close #filenumber"
Changes to
"Close #1"
Edit: #bluepeter
Code:
Sub CreateTXT()
Write #1, sLine
sLine = ""
Next i
Close #1
End Sub
Wicked works great thanks. Thumbs Up Thumbs Up
The last post was made 7 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 46.57 Kb
