Riejufixing |
uberkron |
uberkron Crazy Courier
Riejufixing |
ThatDippyTwat |
Robby |
Robby Dirty Old Man
Pete. |
Pete. Super Spammer
Posted: 10:45 - 25 Mar 2019 Post subject: |
As above that's just pumping.
Q: Does it start easy and idle well?
A: No - might be a problem
Yes - forget about it and ride. ____________________ a.k.a 'Geri'
Riejufixing |
Posted: 14:11 - 25 Mar 2019 Post subject: |
Robby wrote: | Are you assuming blow-by because air is gusting out of the dipstick hole when you remove the dipstick with a running engine?
That is not blow-by. That is just the consequence of having things spinning around and moving up and down in a small area with not much air. When the piston comes down, all of the air under it has to be pushed out of the way. Usually this is pushed out of the crankcase breather into the airbox, but if you remove the dipstick it will push out of that hole instead. Less resistance.
Blow-by is when your piston rings are failing and exhaust gases are pressurising the crankcases. This means a lot more gas getting pushed into the airbox, and picking up some oil along the way. Lots of oil in the airbox is a symptom, along with fouled plug and smoke (from burning said oil).
Whilst a lot of the 125 4-stroke engines have acquired a reputation for going pop before 30k, this isn't down to piston ring failure. It's usually bottom end failure due to a lack of mainenance. Running out of oil, missed oil changes (often leading to burning knackered oil and running out of it), or people failing to clean the unusual oil-filtering methods - centrifugal oil filters that people ignore, and little gauze screens that require removing a crankcase cover to clean periodically. Blocked screens leads to no oil pressure and a knackered crank. |
OK thanks (people), I'll assume that's what it is. I know what blow-by is. I have not seen such a small engine as this pumping "air" all "out" before.
This engine has a gauze strainer and a "paper" oil filter.
The inside of the airbox is not oily.
I don't know why people stint on oil and filters. A change for 125s, plus an oil filter, is only about a tenner. Ignorance & inability I guess.
Edit: A bit too "modern emissions", this crankcase breather discharging into the airbox malarky. I'm more used to the breather venting to outside, where the slight oil mist is useful to stop things going rusty. |
stevo as b4 |
Robby |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
Robby Dirty Old Man
Pete. |
Pete. Super Spammer
The last post was made 5 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
