EazyDuz |
EazyDuz World Chat Champion
Posted: 20:15 - 05 Apr 2019 Post subject: |
Depends on the bike.
I used to check them regularly on my GPZ500 and they usually did need adjusting.
I checked them for the first time since it was new on my last VFR750 at 45k miles and they didn't need doing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Nobby the Bastard |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 20:58 - 05 Apr 2019 Post subject: |
Only one of my bikes had shims, the CB500. Paid for a full service when I first bought it, it was at 56k and unknown service history. Never checked them after that. All the other bikes have been locknut, usually needed a tweak at some point. Current bike has self adjusting pushrods, so not touched them. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Bhud |
Bhud World Chat Champion
MCN |
MCN Super Spammer
Ribenapigeon |
Ribenapigeon Super Spammer
Courier265 |
Courier265 World Chat Champion
Pete. |
Pete. Super Spammer
Posted: 22:22 - 05 Apr 2019 Post subject: |
Checking clearances is easy if you can get the cover off. No reason not to at least check them at service time. If you find they are fine it costs you not much at all. If they are very tight it'll save you a burnt valve. ____________________ a.k.a 'Geri'
MCN |
MCN Super Spammer
Nobby the Bastard |
Easy-X |
Easy-X Super Spammer
Bhud |
Posted: 01:06 - 06 Apr 2019 Post subject: |
One of those reasons why fairings can be a royal pain in the behind...
Shim arrangements aren't necessarily that difficult to handle though, especially when they're 25mm across and the bike is air-cooled... You just need to find a way to press down the edge of the valve bucket, such as a screw-down tool, to let you pick out the shim. Either that or the folded ziptie down the spark plug hole trick. It depends on the bike. On some very old bikes, there is a gear-driven tachy that needs to be disconnected, and there is no space to get a tool in there, and a lot can go wrong when reinstalling the cams if you have to remove them.
On my XJ600N there are 8 valves, and it takes me about an hour to whip off the tank, airbox, carbs and cam cover, and measure all the clearances. I say about an hour because if anything is a bit close to the limit, the underlying shim may have to come out so you can see what it is and find a suitably-sized new one, if you haven't made a note about it (i.e. if it wasn't put in there by you). Over about 40K (of my) miles, all the shims have been replaced or moved around at least 3 times. If that seems a lot, it's probably a combo of letting the bike get hot, using high revs on every ride and having reconditioned the valves (lapping removed some material) and head once. A fairing coming on or off would add considerably to the time needed for this job... Also you usually have to do it twice: everything comes off to measure and take notes, then everything goes back on, you order your shims, ride around in the meantime, then when they come through the post you install them. |
mentalboy |
mentalboy World Chat Champion
kgm |
kgm World Chat Champion
redeem ouzzer |
EazyDuz |
ADSrox0r |
ADSrox0r World Chat Champion
Posted: 11:19 - 06 Apr 2019 Post subject: |
It's no harder to check shimmed tappets and they are (in my experience) less likely to need adjusting.
All bikes are different though. The VFR750 is surprisingly easy to do considering the complexity of the motor. You whip the tank off, unbolt the airbox and the two rocker covers are looking right at you. Even if you need to change a shim, there's no camchain. You just undo the cam caps and the cam lifts right off the top of the gear drive casette.
The GPZ500 was a ballache. It has two coolant pipes which run down through the rocker cover so you need to drain the coolant and replace the o-rings on the pipes (they are garaunteed to leak if you don't). Locknut adjusters though. I used to just check those when I changed the coolant.
My MZ 660 was a piece of piss. It had tappet inspection covers. You just undid a little cap on the rocker cover and the tappet was looking right at you. Needed angled feeler guages though.
The enfield is super simple to check. You don't even need tools since I put a thumb screw on the tappet cover. Remove cover. Ensure push-rods can be rotated but not lifted up and down. Replace cover. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
ADSrox0r |
Islander |
Islander World Chat Champion
Pete. |
Pete. Super Spammer
Islander |
MCN |
MCN Super Spammer
The last post was made 5 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
