Ribenapigeon |
Ribenapigeon Super Spammer
MCN |
MCN Super Spammer
MCN |
MCN Super Spammer
Ribenapigeon |
Posted: 00:00 - 06 Apr 2019 Post subject: |
A good penetrating oil? 50:50 atf and paraffin.
How about freeze and release spray?
You can dissolve ferrous metal from aluminium using a concentrated solution of hot alum but it'll destroy the ferrous metal. You also need to immerse it in the solution for a protracted period. They use it for getting broken taps out of complex drilled pneumatic valve blocks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Pete. |
Pete. Super Spammer
Posted: 08:42 - 06 Apr 2019 Post subject: |
Stainless stuck in ally - heat it up. They have vastly different rates of expansion. This time of year the ally is going to be a tight grip due to the temperatures.
3-400 degrees should do it. 600 will cause the ally to melt. ____________________ a.k.a 'Geri'
Ribenapigeon |
Grubscrew |
Grubscrew Scooby Slapper
MCN |
MCN Super Spammer
Posted: 10:17 - 07 Apr 2019 Post subject: |
Ribenapigeon wrote: | After a little research apparently a mix of ATF and acetone is the best for releasing stuck disimerler metels. So just need to find some acetone. I dont know what magic substance is in ATF I always assumed it was just a type of oil. |
I Googled that for you.
You're welcome.
https://en.wikipedia.org/wiki/Automatic_transmission_fluid
"Modern ATF consists of a base oil plus an additive package containing a wide variety of chemical compounds intended to provide the required properties of a particular ATF specification. Most ATFs contain some combination of additives that improve lubricating qualities,[2][3][4] such as anti-wear additives, rust and corrosion inhibitors, detergents, dispersants and surfactants (which protect and clean metal surfaces); kinematic viscosity and viscosity index improvers and modifiers, seal swell additives and agents (which extend the rotational speed range and temperature range of the additives' application); anti-foam additives and anti-oxidation compounds to inhibit oxidation and "boil-off"[5] (which extends the life of the additives' application); cold-flow improvers, high-temperature thickeners, gasket conditioners, pour point depressant and petroleum dye. All ATFs contain friction modifiers, except for those ATFs specified for some Ford transmissions and the John Deere J-21A specification;[6] the Ford ESP (or ESW) - M2C-33 F specification Type F ATF (Ford-O-Matic) and Ford ESP (or ESW) - M2C-33 G specification Type G ATF (1980s Ford Europe and Japan)[3] specifically excludes the addition of friction modifiers.[3] According to the same oil distributor, the M2C-33 G specification requires fluids which provide improved shear resistance and oxidation protection, better low-temperature fluidity, better EP (extreme pressure) properties and additional seal tests over and above M2C-33 F quality fluids." ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Posted: 10:43 - 07 Apr 2019 Post subject: |
I didn't want to recommend acetone in case there were any rubber or plastic componants on your sensor. Acetone will destroy them. Paraffin is much less likely to. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Ribenapigeon |
Ribenapigeon |
A100man |
A100man World Chat Champion
Posted: 10:49 - 07 Apr 2019 Post subject: |
Acetone from paint shop or nail varnish remover from poundland or similar - costs just £1.. Look at the back though,some have water in others are 99% Acetone plus some floral scenting -- which is nice.. ____________________ Now: A100, GT250A, XJ598, FZ750
Posted: 11:07 - 07 Apr 2019 Post subject: |
You can buy drums of acetone on ebay for very little money. I use it to clean spilled epoxy off stuff, among many other things. It brings carb componants up lovely. I put them in a jamjar of acetone in the ultrasonic cleaner. Just don't let it touch rubber o-rings or gaskets. It even attacks nitrile gloves after a bit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
MCN |
MCN Super Spammer
The last post was made 5 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
