Ribenapigeon |
Ribenapigeon Super Spammer
Grubscrew |
Grubscrew Scooby Slapper
MCN |
MCN Super Spammer
Posted: 10:10 - 07 Apr 2019 Post subject: |
GP Grease Lithium based.
Copper slip/Anti-Seize.
Zinc Anti-Seize.
Silicone Grease.
Silicone Spray.
Telfon Lubricant Spray.
Engine Oil.
Chain Lube.
WD-40 (or better).
Brake Cleaner.
Thread Locking compound.
De-Greaser. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 10:21 - 07 Apr 2019 Post subject: |
...and for dealer servicing...
https://jackandjilladult-9971.kxcdn.com/wp-content/uploads/2017/12/DJ1315-01.jpg ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Posted: 10:41 - 07 Apr 2019 Post subject: |
What I have, although some of it is quite specific for a particular task
High speed grease (LM).
High load grease (moly disulphide).
Anti seize compound (copper grease).
Red rubber grease.
Silicone grease.
Silicone lubricant.
Various grades of engine oil.
Gearbox oil.
ATF (for forks and few more specific tasks).
WD40
GT85 maintainance spray.
ACF50 corrosion inhibitor.
Chain lube.
Cutting fluid.
Graphite powder. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Ribenapigeon |
weasley |
weasley World Chat Champion
steve the grease |
Posted: 20:51 - 07 Apr 2019 Post subject: |
I don't want to get all contentious like, but that copperslip/ antisieze grease is specifically designed for high temperature applications like exhaust studs, it's not really designed for jobs like caliper pins and so on ........... and here's why.
Copperslip , between brake piston and brake pad is OK , it's a high temperature application, but.....
There is a post on here about a stainless ABS sensor which has corroded into the Ally carrier, the reason being that the metals are far apart in the reactivity series and so electro chemical activity ( corrosion) is more of a problem. A similar thing occurs with aluminium ( such as brake calipers) and copperslip , copper is very noble, Ally very reactive , the result can be corrosion of the Ally caliper. A while ago I was speaking to the ( a well known brake manufacturer) technical hotline and the Tech person I was speaking to said " I wish that Fu*$ing golden shite had never been invented, it causes more problems than it solves. "
Draw your own conclusion. |
Grubscrew |
Robby |
Robby Dirty Old Man
MCN |
MCN Super Spammer
Posted: 15:06 - 08 Apr 2019 Post subject: |
NASA use copper grease on aluminium alloy where stainless is in contact with it. They published a paper. It was extremely thorough, even down to how much you should put on each fitting (lots). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
A100man |
A100man World Chat Champion
weasley |
ThunderGuts |
MCN |
MCN Super Spammer
MCN |
MCN Super Spammer
Wyberton John |
Wyberton John Nova Slayer
Posted: 22:37 - 10 Apr 2019 Post subject: |
When I put cable lube into Amazon search it showed me a page full of Durex... ____________________ Fazer Thou Gen 1 |
The last post was made 5 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
