| Author |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 12:58 - 19 Apr 2019 Post subject: Honda Forza 300 |
Hi,
Today i took a Honda Forza 300 for a test ride at Blackpool Honda, Ive been looking for something more practical to commute on, i took it down the 55 first and thought this seems sluggish till I look down and saw it was reading 70mph, off at the Garstang Rd turn off and into town around Stanley Park, no gears and clutch to worry about, but still found I nearly tried to use the back brake as a clutch. so after arriving back at the dealership Im now deciding what to do, keep the 500 or take the scoot.
Any one else had this dilemma?.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Back to top |
| Shaft |
 Shaft World Chat Champion
| Back to top |
| Oldie |
 Oldie Brolly Dolly
| Back to top |
| Mark65 |
 Posted: 17:19 - 22 Apr 2019 Post subject: |
Thanks, decided to give it a try, will look next summer for a motorcycle for nice days, pick it up next Saturday, hopefully it will be all good.
| Back to top |
| Brava210 |
 Brava210 Crazy Courier
 Posted: 18:33 - 22 Apr 2019 Post subject: |
I've had mine since new for 3 years, really good and with the Honda topbox has massive storage ____________________ Honda Novio, Puch Grand Prix, Suzuki AP50, CZ 125, Wassell 125, Montesa 348,Honda 125TDC, Suzuki 100ER, Suzuki GSF650 Bandit, Aprillia Pegaso, Honda PCX125, Honda Forza300, BMW G310 GS, Suzuki SFV650, Honda CB500X
CHARLEY SAYS " ALWAYS TELL YOUR MUMMY BEFORE YOU GO OFF SOMEWHERE" |
| Back to top |
| Kentol750 |
 Kentol750 World Chat Champion
| Back to top |
| Shaft |
| Back to top |
| Kentol750 |
| Back to top |
| Shaft |
| Back to top |
| stevo as b4 |
| Back to top |
| Shaft |
 Posted: 21:58 - 22 Apr 2019 Post subject: |
| stevo as b4 wrote: | Kentol is a spec/bling/top of the range Queen.
If an SP/SPR Fireblade came out with some extra trick shiny bits, no matter how good or capable the std model is he wouldn't see it as good enough or desirable.
He recently tried to say that a proper supermoto has to be a non road legal race bike that could not be bought new in supermoto configuration, and needed to be hand built from scratch. |
The X-ADV is an amusing branding exercise, essentially an NC750X with chunky tyres and some radical(ish) bodywork, the same NC750 that everybody says is the most boring thing in the world.
I quit often encounter one on my ride home from work and yes, he is quicker than me in a straight line (he should be, his bike is 18 years younger, with a larger engine) but I still sit next to him at the lights, because I can filter just as well as he can.
My bike cost 10% of his  ____________________ Things get better with age; I'm close to being magnificent........
| Back to top |
| stevo as b4 |
| Back to top |
| Shaft |
 Posted: 22:22 - 22 Apr 2019 Post subject: |
| stevo as b4 wrote: | No help to OP, but I've been out pillion on a Forza 300 this weekend, and I didn't like it tbh. Had a go on it after two up also. I've always struggled with big long heavy scooters, though the Forza isn't that heavy or unmanageable really like the bigger ones.
Its no good for a 6'2 pillion, and all the weight is over the back wheel which makes it feel nervous and vague at the front. Couple that to the slight delay in the auto clutch take up and it's not confidence inspiring in town traffic.
Then again what the fuck do I know, as the only bikes that are comfortable, and easy to ride for me are tall trailies where you sit much more over the front end, and have lots of control with big wide bars and plentiful steering lock.
I wouldn't swap say a DT125R for a Forza, and even less so for something like a T-max. |
Like everything, you get a handle on the best way to ride them.
With a proper CVT, you get used to never completely shutting the throttle; at a standstill, you hold it at just above tickover, to ensure the transmission is engaged, like holding a clutch at the biting point. If you really want to launch, you hold it open a bit more, with the rear brake applied, then time releasing the brake to going WOT and you take off like a rocket from a bottle.
I thought my XL600R was brilliant in traffic, as you say, big wide bars, weight on the front, grunty motor, a real pojnt and squirt missile; absolutely shit over 60mph, never had any confidence in handling at speed.
As you have said elsewhere, if you want the ultimate performance from a bike, buy one that's designed to do what you want it to do, but anything else you ask of it will be compromised.
I happen to think, after years of owning all sorts of bikes, a maxi scooter could be a good all round compromise, because I've lived with one and went into it thinking the worst.
BTW, I've had a 16 stone bloke on the back of my Wing and had to do an emergency evasive, no problem, didn't even think about it. Maybe the bigger scoots have better suspension. ____________________ Things get better with age; I'm close to being magnificent........
| Back to top |
| stevo as b4 |
 Posted: 23:12 - 22 Apr 2019 Post subject: |
Yeah, it's definitely an adaptation of riding style needed compared to riding almost any other bike I'd say. I havnt ridden a twist and go for 6 years until yesterday, but the light small but twitchy little 50-125cc ones are what I'm used to.
I get your point about pre- loading the transmission when near stationary, and also they tend to really drop into turns too quickly unless you have the throttle open, and on the open road I found the weight distribution and maybe it's also the small wheels or the long wheelbase, you have to kind of swing it into bends as they don't progressively lean like a bike.
I agree that trail bikes are bloody horrible for over 60-70mph and for long straight roads, or even when it's very windy as sitting up like a sail blows you all over the place. But in stop start traffic, slow speed maneuvering or point and squirt down twisty country lanes, I pretty much love them.
As I said right tool for the primary task is the best option, but I don't need anything other than a fun tool, and like to think I could still off road too. |
| Back to top |
| Mark65 |
 Posted: 14:37 - 23 Apr 2019 Post subject: |
Hi,
Last scoots I rode must have been over 25 years ago, Vespa and Lambretta, the scoot is aimed at stress free riding, easy to clean and maintain. I think it should be fine, time will tell. I will look next year for a used big bike for those sunny days. Another main reason to swap is i get numb hands easily especially my right hand, tried grip puppies and different holds but seems to be getting worse as I get older, might be because they have been singles and twins.
Thanks for the replies.
| Back to top |
| barrkel |
 barrkel World Chat Champion
 Posted: 03:17 - 24 Apr 2019 Post subject: |
Forza 300 has basically the same engine as the SH300, but the frame is significantly different - I'd expect it to be more rigid - and it's also a bunch heavier.
For me the tradeoff would be on ratio of higher speed roads to city traffic. The Forza would be slightly better suited to longer spans on NSL, and the SH300 for filtering through city traffic. Though if you spend a lot of time at NSL or a road where you can reliably make that speed or higher, a geared bike can easily be a better choice.
I don't ride my SH300 any more, until scooter crime drops, as I've been bike-jacked once and chased for my scooter a second time. Main downside of Hornet as an alternative is lower tank range and about double fuel spend. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Back to top |
| kgm |
 kgm World Chat Champion
| Back to top |
| Mark65 |
 Posted: 11:36 - 15 Jun 2019 Post subject: |
Hi,
So to update my Forza 300 experience, I've had it for 2 months now and done 1200 miles on it, is it what I thought it would be?, well yes and no.
MPG 84-87 every week on my commute which includes going over the beacon twice a day, flat roads going easy 88-93, today's ride to Blackpool at 70mph on the motorway it sat at 82mpg so all pretty good.
Storage is great, loads of it, comfort is ok but i get a sore back midway up after a while on it ,not sure why, maybe the upright position or maybe im getting old.
No numb hands or fingers from vibrations, which is something i suffered with on the 300 and my 500 single and twin, now the suspension.. if the road surface is good its fine if not the front bottoms out easily, i weigh 106kg and once im sat on it i am lucky if theirs 2.5 inches of travel left, the rear is livable but seems to be soft or stiff when adjusted, too soft and it can bottom out also (front and rear checked with a zip tie).
Engine is loosening up and is nippy, 0-40 before you know it.
After looking into it front suspension upgrade from YSS including emulators,springs,spacers and adjustable preload caps comes to £180
and the rear shocks are around £300.
I do like the bike but i miss the bigger bike so im stuck, most singles and twins cause my hands and the right one especially to go numb fairly quickly, inline fours are screamy and mpg drops to 40-50mpg it seems, so im not sure where to go from here, chance the upgrade on the scoot or maybe try an NC750 (good mpg, low revving, handle my weight better). Jus to add my commute roads can be shitty and not that good in some parts, i even thought of the CRF250L but it may be to tall. Also, its so easy to clean, no more on knees trying to get shit out of the nooks and crannies, no chain maintenance either.
any advice or opinions please.
Thanks
| Back to top |
| Kentol750 |
| Back to top |
| P.addy |
 P.addy Red Rocket
| Back to top |
| Shaft |
 Posted: 15:23 - 15 Jun 2019 Post subject: |
Full suspension upgrade for under £500 seems like reasonable value.
what is it that you actually miss about a 'normal' bike?
If your history is your sig, the biggest bike you've owned is a CB500 and, with the greatest respect, they are for from the best thing on the planet and I would take an educated guess that, apart from the suspension, your Forza probably does virtually everything at least as well.
If you want a little bit 'more' why not go for a bigger scooter? ____________________ Things get better with age; I'm close to being magnificent........
| Back to top |
| Mark65 |
 Posted: 17:27 - 15 Jun 2019 Post subject: |
Paddy i need the mpg for commuting, funny thing is i like it sometimes and not others.
Shaft, yes my experience is limited to those bikes, i miss the way the bigger wheels role over the bumps, i planned on keeping the scoot and bying a used big bike next year, i wasnt sure if that was expensive for the shock upgrades, i might just try the front first. I do find cars tend not to give me the same space as my bikes but yes it does everything bar the bumps as well, maybe i am still getting my head round its a scooter
Thanks ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| Back to top |
| barrkel |
 Posted: 19:04 - 15 Jun 2019 Post subject: |
| Mark65 wrote: | Shaft, yes my experience is limited to those bikes, i miss the way the bigger wheels role over the bumps, i planned on keeping the scoot and bying a used big bike next year, i wasnt sure if that was expensive for the shock upgrades, i might just try the front first. |
I'm not sure the suspension change is going to make a significant difference. You may have more travel on the front, but the rear still needs to do a lot of work since the engine goes up and down too, so unless you get out of your seat on those bumpy bits it could still be a rattly ride.
I wouldn't expect YSS or Hagon shocks to perform better than stock apart from being more closely adjusted to your range, which you could probably get by adding a spacer to the stock shock springs. It's not hard to open the top of the fork legs to test out - they're held in with an interior circlip, exposed when you push down on the cap while gripping the stanchion, if it's like the SH300. The fork legs can be removed easily enough if you take off the front wheel and mudguard, and have tools that can reach the two nuts attaching them to the steering stem. No major fairing teardown necessary, on the SH300 at least.
I've replaced rear shocks with Hagons on a couple of SH300s due to leakage and in one case seizure on one side. Definitely an improvement on an 6+ year old shock, but not sure it was as good as new, and I've had two SH300s from new.
It does seem to me that you may be happier with one of the NC750s, but it also seems that trying to save on mpg by buying newer, more efficient bikes is a bit of a false economy, depreciation buys you a lot of fuel. I was looking at a YBR250 as an alternative commuter in part because it has a 19L fuel tank, it's the constant refuelling that irritates me. But perhaps the vibrations wouldn't work out, I don't know. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Back to top |
| caljay |
 caljay L Plate Warrior
| Back to top |
| barrkel |
 Posted: 21:41 - 03 Oct 2019 Post subject: |
I had occasional bad wobble on SH300 at 70mph when there was too much weight too far back, in the top-box. Pretty much the same engine, but quite a different frame, so of limited relevance.
Scooters have more frame flex generally than big bikes, if there's an oscillation, there's more bend for it to feed into the steering. Also, with rear suspension having to move the engine along with everything else, undulations in the road in the middle of a corner can cause a bit of sea-sickness.
Some people are just the wrong weight for some bikes. Often it comes down to weight distribution. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
| Back to top |
The last post was made 7 years, 42 days ago. Instead of replying here, would creating a new thread be more useful? |
