| Morpheus Cane |
 Morpheus Cane L Plate Warrior
 Posted: 19:16 - 02 May 2019 Post subject: Fuel tank rust |
Hi all,
Looking for some advice on the inside of my fuel tank off my "004 Honda CBR600RR which has some surface rush, this has happened as the tank has been off the bike a while after the fuel pump failed
Some of it seems to rub off but I was wondering what peoples opinion is, Do i need to worry about it? Should I try to clean it out with something?
Sorry if image to big I could not work out how to shrink it
Many Thanks
https://i775.photobucket.com/albums/yy40/CptDave/IMG_20190502_185233.jpg |
| MarJay |
 MarJay But it's British!
| MarJay |
 Posted: 19:41 - 02 May 2019 Post subject: |
Ok got the pic. It's surface rust but ideally it needs to be dealt with. Vinegar is one option.
Here's another option:
https://www.frost.co.uk/brands/por15/por15-prep-metal-ready-946ml.html
Or you could just fill up with fuel and hope it doesn't get any worse... but it's on the edge of being able to do that IMO. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Morpheus Cane |
| Riejufixing |
 Riejufixing World Chat Champion
| Grubscrew |
 Grubscrew Scooby Slapper
| Morpheus Cane |
 - Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 08:47 - 03 May 2019 Post subject: |
On resto/rebovation, I tend to do a full POR 15 treatment, these days, as a matter of course.... saves stupid later on!
To aid the de-gunking chemicals at the beginning, I will wash the tank repeatedly with plain water, to try and get out as much loose-ish crud and silt; then I will do a couple of vinegar soaks, to get rid of a bit of heavier rust, before I chuck in the 'expensive' POR 15 stuff.
It works a treat, BUT, you have to be assiduously diligent to the instructions, vis turning the tank every so-many minutes to get it to cover the while inside area, on each 'bath'... and final treatment is the 'paint' or fuel-proof lining, which takes about a day to dry, but a week or so to properly cure and become petrol-proof.
Once 'done' it's pretty much fill-and-forget, the tank dont rust inside, and it saves faff with in-line filters, especially after-market ones that have a habbit of causing an air-lock and lag in the flow, giving running issues.
Plus, doing before anything else, gives time to get on and do everything and anything else, whilst you are letting chemicals 'soak' or the the tank lining cures properly, before putting petrol in it.
The full process, is only maybe a couple of hours 'hands-on' work, but its in five or ten minute taskes between leaving the dang tank to soak or dry or cure, stretching it out to over a week or more, IF you follow the instructions properly.... it is NOT a ten minute trick!
But, cold hard experience says its a dang site easier to do the inside treatment at the beginning, and not have the hassles later, when the tank starts to re-silt up, or pin-hole and leak, especially if it happens to leak through nice new external paint and decals, ruining them in the doing!
On something not-so-old, and not so derelict, it probably isn't so crucial, B-U-T.... I did it about a decade ago to my Seven-Fifty, which had about as much surface rust at the time, mainly 'cos I could... and it saved silly questions later.... and whats £50 in the grander scheme, when the brakes need 6 new pistons or whatever,and the carbs an ultrasonic swill!?!
As shown? POR15 then may be a bit of over-kill.... but your call.
For the surface rust in the pictures, I would probably do the full monty on it, and be damned... or leave it as is, and be damned....
If it gonna dissolve and clog, it gonna dissolve and clog, you will have to clean petcock gauzes and probably carbs... but you probably should anyway; so it would point you towards doing a bit of worthy preventative along the way, and you wouldn't waste so much time and effort up-front doing a 'half' job, sort of cleaning the tank.... but never really getting it all that clean, or putting the petrol-proof lining on the metal to stop it coming back again.
So, in for a penny, in for a pound... you either do it all, and do it pukka... or you do nothing at all.... that's my sort of reasoning on the matter.... but as said, your call. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Easy-X |
 Easy-X Super Spammer
 Posted: 10:25 - 03 May 2019 Post subject: |
So I take it from cursory examination of the POR 15 website this is rust treatment followed by coating the internal surfaces with a petrol-proof plastic film?
If it's such a great thing how come manufacturers don't apply such a coating from the off? Seems like it would be much easier to do at the factory  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| MarJay |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 11:54 - 03 May 2019 Post subject: |
| HardlyDavidson wrote: | So I take it from cursory examination of the POR 15 website this is rust treatment followed by coating the internal surfaces with a petrol-proof plastic film?
If it's such a great thing how come manufacturers don't apply such a coating from the off? Seems like it would be much easier to do at the factory  |
First off and last off why they dont pre-treat tanks, or an awful lot of components, is, Cost.
The POR15 'kit' to do one tank, costs aprox £50... it aint cheap.... and the 'customer' don't see it. More they dont see the 'lack' of the stuff until well beyond the warranty period either.
OP's got a 10+ year old bike, here, and it's only because the tank was left empty & deralict that he's 'seen' internal surface rust. During 'normal' service, the internal faces of the tank are 'protected' to a large degree against oxidisation by the fact there's petrol sloshing around in there, keeping the metal wet, and out of the way of oxygen.
So off the top; the very first reason that the manufacturers dont line the tanks is the cost/price ratio... lining the tank wont add as much as it costs to line it, so it would have negative effect on the profit margin.... that really is the bottom line.
Meanwhile, the 'idea' that it must be easier to do on a brand new part, during manufacture, than after, as a renovation process, is a bit naive. Logically it aught to be, but; it isn't.
Key to the POR15 process is the 'Key' actually getting the gloop to stick to the metal. In the 'process' the kit contains a very caustic decreasing agent, and then a pickling solution to etch and activate the metal to take the gloop.
As made, a new steel tank will have been pressed from sheet fresh from t'mill, and likely coated in oil a) as some form of rust prevention in transit and storage before manufacture, and b) as a handling 'aid' to stop the sheet sticking so much to tooling, when it's pressed into shape.... add a bit of soot and carbon where that oil will have been burned when the base welded to the top.... ACTUALLY, the cleaning and degreasing you would need to do to a brand new factory fresh tank, isn';t actually any less than you have to do to something that's sat in some-one's back yard for quarter of a century!
Sure, it shouldn't be 'as' dirty or rusty in original manufacture... but; that's just a question of degree... and how filthy the solutions might come out of the tank when you go through the process... the whole process would still need doing; the same number of stages, the same number of standard-hours of extra manufacture, to coat the inside of the tank....
And we are BTT, and how much 'added value' it might add to the sicker price,compared to how much added cost it adds to the manufacturing process.
There are many other ways about, and for example, what if you pre-coated the metal before forming... but then you have to consider whether that coating will be damaged by forming or processing... imagine trying to weld a piece of steel with a celphane sheet still attached.... and we are back to swings and round-abouts, with an ever-present accountant hovering over your shoulder muttering "The BOTTOM LINE!" ever more incessantly. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Easy-X |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:32 - 03 May 2019 Post subject: |
| MarJay wrote: | Nah, I wouldn't do that unless you were at the point of leaking... I did it to my RD tank and it didn't work that well... |
As far as I can tell, most POR15 disappointment can be attributable, to either rushing the job, on the full process, and not actually gettig the tank assiduously clean at the start, or giving it enough etch to adhere the lining, or trying to cheap-skate and rather than painting the £50 for a full treatment kit, buying 'just' the lining paint for about £20 for double the quantity, and chucking that in without the clean and ksy baths before hand.
Ironically, the idea of leaving it until it's about to leak is probably a bit eroniouse; earlier you do the full treat, presumably the less far gone the tank to start with, and more time you give it to dry and cure in process, the more successful it's likely to be... BUT when a tank has gone and pin-holed... that's actually when POR15 can come into its own.
If you buy the full 'kit' it comes with some patch-cloth, you can stick over a pin-hole like a push-bike inner-tube repair, that you paint over to 'patch' the hole, when you find it, and soaks up the lining paint from the inside when you treat, to give a pretty good patch repair.
I've done a couple of sieve-like tanks with the repair cloth, and it 'does' work, and work well.
Is a dilemma, whether a POR15 kit is worth it compared to buying a 'better' 2nd hand or even new tank...b-u-t, anomaly there is that a 'better' 2nd hand tank, may not be all that much better, or better for all that long, compared to what you got, and you would be as well doing even the replacement tank, before you used it.
Incidentally; it's NOT just for steel tanks. What made me try it, was actually reports from US based folk, grumbling about alcohol based or high alchohol e-fuels, causing the fibreglass of GRP tanks to de-laminate, or turn to jelly! Particularly on old trials bikes, like my Montesa, that normally came 'as standard' with a one piece GRP seat/tank unit.
Co-incidentally, MY Cota, an original UK Market model, came with the GRP seat/tank cut away at the bottom, to become merely a cover over an Aluminium fuel tank, due to UK C&U regs of the time, that forbade GRP or Plastic fuel tanks... hence not really an issue on that one... but raised the question, with the Septics, and folk in the UK who bought grey-imported examples from Spain, at the start of e-bay-excitement, who pondered whether a UK market model seat & tank would be better than trying to fix delaminated glass or treat with POR15.
Here, the lining gloop, stops the fuel from being in contact with the GRP resin, and again, can be a pretty good 'fix' for a tank that's been bashed or started to go jellified. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| BTTD |
 BTTD World Chat Champion
| Robby |
 Robby Dirty Old Man
| Easy-X |
 Posted: 12:48 - 04 May 2019 Post subject: |
| Robby wrote: | The meths step is important. Meths will bind with water, but also go through you fuel system in low enough concentrations. Otherwise the residual water will just sit at the lowest point in the tank and rust away. |
Haha! Good point I always hear mentions, concerning Ethanol-fuelled engines, of how the fuel can go bad if you let it sit and suck in water from the atmosphere. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Robby |
 Robby Dirty Old Man
| temeluchus |
| Islander |
 Islander World Chat Champion
| Morpheus Cane |
| Riejufixing |
| Robby |
 Robby Dirty Old Man
 Posted: 10:01 - 06 May 2019 Post subject: |
Not surprising. I use phosphoric acid liberally to de-rust things, because I'm too lazy to use sandpaper. I also use it for my galvanising kit, because it will shift rust and also remove old zinc plating. Great when I bought a bunch of yellow plated bolts and I wanted them silver zinc, once the old yellow plate was etched off I had a perfect base for silver plating.
However, metal will rust very quickly after an acid treatment. It needs to be treated within minutes. A bit of oil (or petrol for fuel tanks) does the job, then it will last for years. |
The last post was made 7 years, 101 days ago. Instead of replying here, would creating a new thread be more useful? |
