Just Cause 4 PC
King29
PostPosted: 23:47 - 15 May 2019    Post subject: Just Cause 4 PC Reply with quote
Anyone playing this? can't seem to get it to save? played an hour and then reloaded it and had to start from the beginning?
Not fun.
RhynoCZ
PostPosted: 14:55 - 16 May 2019    Post subject: Reply with quote
Did you run the game as administrator? Is it on your C:\ (system) drive?
King29
PostPosted: 16:46 - 16 May 2019    Post subject: Reply with quote
It's on drive F: I just launch it via Steam.
owl
PostPosted: 17:07 - 16 May 2019    Post subject: Reply with quote
https://steamcommunity.com/app/517630/discussions/1/1744479064009526728/
Few people reporting same issue, try
Disabling cloud save
Running game as admin
If that fails, try figure out where the saves are going/meant to be going and make sure the permissions on that location are set correctly.
You said installed on F: ? Is it in a folder on the drive or just installed in the root?
King29
PostPosted: 17:21 - 16 May 2019    Post subject: Reply with quote
It's installed alongside my other steam games. The save folder is under c drive, under square enix; just cause 3 folder is there (which works fine) and just cause 4 folder which does not.
owl
PostPosted: 17:24 - 16 May 2019    Post subject: Reply with quote
Can you go into the JC4 save folder? Can you create a new file in the that folder? Right click new > txt or something
King29
PostPosted: 17:42 - 16 May 2019    Post subject: Reply with quote
There is no save folder but I can write to the JC4 folder.
This is all there is.
https://i.imgur.com/CNkWPx4.jpg
owl
PostPosted: 17:57 - 16 May 2019    Post subject: Reply with quote
Do you use GeForce NOW?
Did you disable the cloud save feature?
Someone also mentioned running it in compatibility mode fixed the issue for them.
Strange one for sure.
King29
PostPosted: 00:22 - 17 May 2019    Post subject: Reply with quote
I have an Xbox one. I signed up for game pass for £1 for 3 months, Just Cause 4 is there, I've downloaded it and it's playing/saving as it's supposed to.
Thank you anyway.
The last post was made 4 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.5 - MySQL Queries: 17 - Page Size: 58.48 Kb
