Jay2903 |
Jay2903 Scooby Slapper
Easy-X |
Easy-X Super Spammer
doggone |
doggone World Chat Champion
Robby |
Robby Dirty Old Man
Jay2903 |
Jay2903 |
Jay2903 |
Bhud |
Bhud World Chat Champion
Jay2903 |
Bhud |
Jay2903 |
Jay2903 |
yen_powell |
yen_powell World Chat Champion
Bhud |
Posted: 21:55 - 05 Jun 2019 Post subject: |
Jay2903 wrote: | One more thing, I tried to get the bike to idle at a reasonable speed, it’s up at like 3.5k at the moment. The idle speed screw is all the way out already. Does that mean I’ll have to adjust the pilot screws ? I set them at 2 turns out which is in the middle of the recommended range. |
It isn't correctly set up. If you wind out the idle screw all the way it will just stop. When the carbs are correctly set up and clean, you can use the idle speed screw to get it idle steadily at around 1k to 1.2k rpm.
Different carbs were fitted to different model years of the GT550. The early ones (like mine) have TK26, which use brass-tipped float needles. These must be kept spotless, or they don't seat properly and they let lots of fuel through even when the float is floating. Even when they're good, they let fuel through.
Whichever model of carb you have, I suspect that if your idle speed screw is all the way out but the engine runs ("idles") at 3.5k rpm, there is a problem with either your choke or float needles. Make sure your choke plunger is pushed all the way in. With the choke all the way in and the idle speed screw all the way out, the bike shouldn't idle at all. If it does, then look closely at your bank of carbs and make sure that the choke rod is shutting off each and every choke circuit on every carb completely.
Have you completely cleaned out your carbs? If it's still on your "to do" list, then I recommend getting a big box of Ebay petrol resistant rubber seals in metric sizes, because when you separate them, all the rubbers will come crumbling apart. Plus, you can get cheap carb rebuild kits on Ebay. They are almost completely useless but you are likely to need those things that seat the float needle.
The mixture settings (2 turns out each) are fine - come back to them when the bike's running properly. For now clean the carbs, set the float levels correctly and get a rough carb sync by setting them all to factory level on the bench. It will be enough to get it running correctly, then you can do a proper synchronisation and mixture tuning later. |
Jay2903 |
Posted: 22:09 - 05 Jun 2019 Post subject: |
Bhud wrote: |
Whichever model of carb you have, I suspect that if your idle speed screw is all the way out but the engine runs ("idles") at 3.5k rpm, there is a problem with either your choke or float needles. Make sure your choke plunger is pushed all the way in. With the choke all the way in and the idle speed screw all the way out, the bike shouldn't run at all. If it does, then look closely at your bank of carbs and make sure that the choke rod is shutting off each and every choke circuit on every carb completely.
Yea I cleaned the carbs and set the pilots screws when I had them off, the choke plungers are all functioning fine. The choke is off (pushed in) when it’s at the 3.5k idle. It’s a G9 with the Keihin carbs.
I thought screwing in those pilots screws a tad would drop the idle sufficiently ? |
Jay2903 |
bikenut |
bikenut World Chat Champion
Robby |
Robby Dirty Old Man
Jay2903 |
Jay2903 |
Jay2903 |
Bhud |
Jay2903 |
bikenut |
Sister Sledge |
The last post was made 4 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
