| vitus detritus |
 vitus detritus Derestricted Danger
| Easy-X |
 Easy-X Super Spammer
| vitus detritus |
| BusterGonads |
 BusterGonads Trackday Trickster
| WD Forte |
 WD Forte World Chat Champion
| sickpup |
 sickpup Old Timer
| vitus detritus |
 Posted: 01:06 - 10 Jun 2019 Post subject: |
Although I forgot to connect the +ve from the relay, I did connect the +ve from the output of the reg/rec. Have a read - https://www.triumphrat.net/maintenance-and-workshop-talk/68040-weak-charging-system-the-solution.html
Please note that my misfortune is entirely due to my stupidity - and their hack works, and works well. I got 14.7 v measured at the battery before I went looking for other earth issues and forgot to hook up everything correctly to the battery. Twat.
I have since discovered that there is a diode in the ignition and there is a slim chance that I popped the diode and not the ECU. I will investigate and report back. ____________________ if it ain't broke, don't fix it |
| Robby |
 Robby Dirty Old Man
| sickpup |
 sickpup Old Timer
| vitus detritus |
 Posted: 07:38 - 12 Jun 2019 Post subject: |
Hey Sick Pup
no, I ain't lyin'. On the reg/rec side of the loom, there are two positive wires and two negative wires that connect to the standard connector. There is also a third positive and negative, which I added that go from the reg rec loom to the battery direct. When I popped the starter relay fuse, all negatives were connected, but I only connected the added on +ve, not the +ve batter terminal of the bike (which connects the relay I think).
So although it got power to crank, it must have done so via the loom, not direct from the battery.
What is a 'pattern' ignition ? Do you mean 'aftermarket' ?
I am going to have a look at the ignition and patch in a 9 v battery to the ECU and see if the fuel pump primes. If not, it's a fair bet I've popped the ECU. But that still wouldn't explain why the stator was getting hot - which I suspect is a bad earth somewhere - which, apart from my stupidity, is why I'm here in the first place. Any suggestions gratefully recieved. ____________________ if it ain't broke, don't fix it |
| Robby |
 Robby Dirty Old Man
| vitus detritus |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| vitus detritus |
The last post was made 6 years, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
