Central Heating overhaul..
PostPosted: 13:48 - 17 Jun 2019    Post subject: Central Heating overhaul.. Reply with quote
The 12kW 1970s Baxi Bermuda in my three bed semi can just about take the chill off in winter. Most of the rads though are only getting luke warm and rudimentary flushes have little effect. So I call in my boiler mate for an appraisal. His verdict new 30kW Vaillent (combi) boiler (fair enough) and new rads all round (seven) and new Hive controller (a must have he says).. Total 4k ish
The price I think is fair to essentially completely renew the system however as I may have stated in the past I am pathologically mean and in any case I don't have 4K.
My starting point was going to be. Cheapest 25-30 KW boiler I can find with an SS heat exchanger. Powerflush and magna-clean fitted.
Thoughts?
DRZ4Hunned
PostPosted: 13:58 - 17 Jun 2019    Post subject: Reply with quote
My Glowworm 30kw recently went kaput after only 4 years in my 2.5 bed ex council semi.
Replaced it with a budget Ideal Logic 25kW from Travis Perkins for £550 and got a local plumber to fit it with a new flue for £300 cash.
I have no idea why plumbers charge so much as he was in and out within the morning, so £300 for half a days work!
I wouldn't say 4k is particularly good or "mates rates"...
DRZ400-SM
FZS600
Freddyfruitba...
PostPosted: 14:01 - 17 Jun 2019    Post subject: Reply with quote
It's absolutely standard practice to recommend renewing the whole system in these circumstances because it's the only way the engineer can guarantee its going to work properly afterwards, whether that's due to clogged-up radiators, knackered radiator valves, inefficiently fitted pipework, etc etc.
I can relate my own experience about 15 years ago of converting from a low pressure to a mains pressure central heating system like your proposed one... we kept the old radiators and everything was fine for a few days... but then, one of the old bedroom radiators developed a leak, right in the middle of a panel at the back, where a rust pinhole had formed due to the higher pressure in the new system. By the time we found out, gallons and gallons of water had leaked and soaked the bedroom carpet, dripped through the ceiling and trashed the sofa in the room below. Not pretty.
My neighbours replaced their boiler recently, kept the old radiators against advice, and all was absolutely fine. Yer pays yer money and yer takes yer choice.
P.
PostPosted: 14:19 - 17 Jun 2019    Post subject: Reply with quote
I would ask that all pipes are checked, had a more powerful one popped in and a pipe shat itself above the clothes cupboard... tasty.
Seems a lot though, non-mates rate 6 rads, new boiler and 1.5 days of 2 people was £2600.
No hive or any of that BS, I have a timer that does 2 hours of hot water a day and when its cold does heating from 4am till 8am and 5pm to 8pm. I dont care about ambient temps and having it controlled from my phone... its all pre-set.
PostPosted: 14:21 - 17 Jun 2019    Post subject: Reply with quote
I think that was his angle..
One thought I had was to power-flush the system as it stands today - about 100 quid to hire the kit for a weekend - connects to pump flanges. This may uncover any obvious flaws in the current system
PostPosted: 14:22 - 17 Jun 2019    Post subject: Reply with quote
Quite - I was somewhat irked by his insistence on that aspect.
Riejufixing
PostPosted: 15:06 - 17 Jun 2019    Post subject: Re: Central Heating overhaul.. Reply with quote
DIY everything except the boiler installation.
You used to be able to get a "Baxi Bermuda BBU HE" to replace your old boiler (a friend had one to save re-doing the pipework and ripping stuff out), but I think they're now discontinued.
If your old rads are sound, keep them, you don't have to change the whole system. If you know they're clogged, unbolt them, take them outside and just flush them with a hosepipe, IF you need to.
Edit: your old system is reliable? It'll "save" you about £250/year at a guess to switch to a new condensing boiler (and I'd keey the cylinder IIWY).
PostPosted: 15:19 - 17 Jun 2019    Post subject: Re: Central Heating overhaul.. Reply with quote
I've done this in the past, but I'm a bugger for spilling dirty rad water onto light carpets Rolling Eyes hence thoughts to hire a powerflush.
I'm also a fan of the conventional boiler, however I'm consider a loft conversion in the future so to do away with header tanks will be a bonus.
Riejufixing
PostPosted: 15:54 - 17 Jun 2019    Post subject: Re: Central Heating overhaul.. Reply with quote
Yes. That is not what we are wanting!
t121anf
PostPosted: 16:46 - 17 Jun 2019    Post subject: Re: Central Heating overhaul.. Reply with quote
DIY the boiler too, just leave the gas for the gas fitter, it's the only bit by law you can't touch.
Freddyfruitba...
PostPosted: 17:20 - 17 Jun 2019    Post subject: Reply with quote
Yes that's complete BS; there's no reason at all to foist Hive-type kit on an unwilling punter; even if you're not quite as stone-age as Paddy it's perfectly fine to use conventional thermostats and programmers.
Powerflushing is also a damned sight more effective than a hosepipe, too
Fine, providing the fitter is happy to take responsibility for the whole boiler installation; but the vast majority of them wouldn't touch an arrangement like this. Far too much chance of something going wrong and having to diagnose the customer's dodgy workmanship etc. If yer man won't entertain the prospect of keeping the old plumbing and radiators, he surely won't be happy with the customer doing his own plumbing.
Riejufixing
PostPosted: 17:35 - 17 Jun 2019    Post subject: Reply with quote
If as I said the radiator is removed, I do not think it is as effective.
The last post was made 4 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 17 - Page Size: 80.11 Kb
