Chinaboy |
Chinaboy World Chat Champion
Posted: 07:09 - 20 Jun 2019 Post subject: Ford Fiesta immobilized |
Long story really short, I got a Ford Fiesta zetec tdci 2007 model.
As its stored (sorn) at my parents, I ask my father to start it and run the engine until warm and keep the battery fully charged for me to keep in in order.
Anyway, last year (October) he got in it for its weekly run, the car would just not start.
He checked the battery. All ok. He checked the key fob batteries and replaced like for like (both keys). Nothing worked, no lights on the dashboard, no click of the ignition, completely dead.
I asked him to get it towed to a local garage, who connected the car to a computer to find a fault code, but no code. No red lights flashing on the dashboard to give a code. No one knows what the problem is.
I have googled the issue, and it seems many have the same problem, but there are no solutions. Even another lady in my village had the same problem with her Fiesta, and when she took the car to the local Ford dealer, even they could not find the solution. She ended up having to scrap the car. Scrapping the car has also been suggested to me via the garage mechanic, who has also asked around for ideas, only to draw a blank too.
I have heard of the coil around the key barrel sometimes can work, or putting the chip from the key in a small void in the key barrel, but I don't know.
Any of the BCF crew have any ideas about this? any mechanics here? I posted on a Ford Fiesta forum, but drew blanks too.
Any suggestions might help.
cheers guys |
Riejufixing |
- Super Spammer
Easy-X |
Easy-X Super Spammer
doggone |
doggone World Chat Champion
Chinaboy |
- Super Spammer
Posted: 15:26 - 20 Jun 2019 Post subject: |
Chinaboy wrote: | Thanks for the replies, yes the battery was checked. By both my father and the guy in the garage. |
As a couple have already asked, including me... How? Just by putting a multimeter across it? It could be fine, but on an unused car, it's the first thing which needs properly load testing, not just checking for 12V with a meter. You'll look a right twat if you rip the dash out and send it to Ford to be told it's fine. If you want an easy test, use the battery with jump leads to try to start another car with the negative lead on the other cars battery disconnected, so it has to use your battery to start the car. If it can start another car, move on in the troubleshooting.
Chinaboy wrote: | . It was said that the immobilser chip set was in this area, but I don't know. |
When I was playing around with my S Type Jag, which uses the Ford PATS immobiliser system, and configuring new transponder chips for spare keys using IDS dealer software and cable, the instrument cluster is actually one of the modules which is part of the immobiliser system. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
leolion |
leolion Scooby Slapper
UncleFester |
bugeye_bob |
bugeye_bob World Chat Champion
Chinaboy |
- Super Spammer
Posted: 09:23 - 21 Jun 2019 Post subject: |
Chinaboy wrote: | Again, for the battery issue, it was taken to a local mechanic who also tested it, I can't 100% tell you how he tested it, |
You need to find out before you or your Dad, go any further really.
Just testing for 12V with a multimeter won't cut it and for a battery on a car left standing for month's on end, I'd suspect the battery.
Get your Dad to do the trick of disconnecting the earth lead from the battery of another car parked next to it, then connect this car's battery to the other car's battery and try to start that car. If it starts, great, if not, the battery will not work under load. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Chinaboy |
Posted: 14:51 - 21 Jun 2019 Post subject: |
Thanks mpd, I will try and get him to do this test just to rule this out.
Just earlier I received a reply back from Ford UK. Thank you for the information you supplies us Mr Chinaboy, but can you please book it in to your nearest Ford dealer so they can do diagnostics.... They didn't add any more.
I replied with 'for a 12 year old car, worth about a grand, do you really think it is cost effective to do this?' I went on to say that if they really wanted to help they should perhaps ask someone in their mechanical department to see if this problem has ever been reported and if so, please inform me back.
I know they wont be helpful and just tell me it must go to the dealer blah blah blah.... |
Pjay |
Pjay World Chat Champion
Posted: 18:43 - 21 Jun 2019 Post subject: |
I dont know if this will be any help for you, but it happened to me on my VW Golf.
A few years back, I hadnt used the car for around a year, I had the use of another car and a bike, so I sorned it. I wanted to put it back on the road and so I booked it in for an MOT and sure enough, the one time I needed to use it, it refused to start. Checked everything over and it all seemed fine, the battery was good in both the car and the fob, so it wasnt that. I called my friend up that specialises in VW and he said that the key is paired to the instrument cluster, so maybe that's at fault. If so its a pain in the anus and expensive to repair. Anyhow he went on to say that it could also be damp related, as often damp can get into the connectors on the inside of the car if they have been not used for a good while. He said to find every connector I could around the cluster and spray WD40 in and around them. So I did it and it worked a treat and the problem never came back.
Now, I know a Ford isnt a VW but maybe something similar is happening. Take a can and get squirting. ____________________ struan80 - I'll go first - satisfied tick 1 |
Chinaboy |
Posted: 15:38 - 22 Jun 2019 Post subject: |
Thanks Pjay,
I can see where you are coming from. When I left the UK last year, I had used the car every day. Afterwards, it was covered in one of those silver car covers and closed up tight, but my father would run it to normal running temperature maybe 10 - 15 minutes at least every week to keep it in order. Damp cannot be ruled out. At this moment though it is at the local mechanic's garage with several other cars he is looking at, so who knows what else is going on now. I also don't think I will be back in the UK for a while so unfortunately I cant do it myself |
doggone |
Easy-X |
Posted: 23:36 - 22 Jun 2019 Post subject: |
I wonder some times if the vehicle absorbs some of the psychic energy of the owner. Ride/drive often? A happy vehicle free of moss in the corners, spiders living in the master cylinder and mice in your air box.
Once left for a while the soul departs and it becomes a lifeless piece of metal ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Chinaboy |
sickpup |
sickpup Old Timer
Chinaboy |
Suntan Sid |
Riejufixing |
Posted: 12:41 - 29 Jun 2019 Post subject: |
"Make sure you've still got your radio code and similar if in use".
Edit: although if the radio hasn't "seen" the battery for a while, I know not... |
The last post was made 4 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
