nutty_nick |
nutty_nick Derestricted Danger
Evil Hans |
Evil Hans World Chat Champion
steve the grease |
Posted: 23:54 - 20 Jun 2019 Post subject: |
Whatever it is, a decent LED will be brighter than a filament (non-decent LEDs also available).
The tricky bit in terms of road legality is focus. How are you achieving a beam pattern? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Easy-X |
Easy-X Super Spammer
WD Forte |
WD Forte World Chat Champion
WD Forte |
Easy-X |
nutty_nick |
nutty_nick |
Triton Thrasher |
Triton Thrasher Could Be A Chat Bot
Easy-X |
Posted: 21:35 - 29 Jun 2019 Post subject: |
Shit! Good point... I got some cheapo LED bulbs for the turd scooter. Doubt they'll handle AC ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
WD Forte |
Easy-X |
Posted: 18:04 - 30 Jun 2019 Post subject: |
stinkwheel wrote: | HardlyDavidson wrote: | Shit! Good point... I got some cheapo LED bulbs for the turd scooter. Doubt they'll handle AC |
Some of the better quality stop and tail/single filament replacement ones will.
The high output, H4 headlight type won't. HOWEVER, nothing stopping you using the full output for charging the battery and running the lighting on DC if you're going down the LED route. My bike is on LEDs and draws 2.4A total if you have the headlamp, flashers AND brake light on all at once. |
Interesting... I could do a bit of rewiring I suppose. Alternatively, how about a secondary reg/rec just to convert the AC to DC and not even stress the existing one or the battery?
(Apologies for the thread hijack!) ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Posted: 18:19 - 30 Jun 2019 Post subject: |
(Apologies for the thread hijack!) |
It's relevant because the C90 system on the OPs bike may well rock direct lighting too. But since he's running what is effectively a brake light bulb, he'll probably get away with a good quality, positive earth LED bulb on an AC circuit. (Positive earth ones have extra electronics in them that allow them to light with current flowing either way, a +ve earh LED will work with a -ve earth system but not the other way round).
However. Most tiddlers which have direct lighting only have a single charging phase with a split coil. When the lights are on, it uses half the coil for lighting and half for charging. When the lights are off, it uses the whole thing for charging. So in most cases, to convert to DC, all you'd need to do is wire the light switch up to the DC output from the ignition and blank off the AC wire. If you do this with standard incandescants, the battery will go flat over time if you use them. LEDs, not so much.
Also worth noting that some of the more basic ones are only half-wave rectified. They just have a high capacity diode in there instead of a rectifier and zennor. These are shite, they cook themselves and the battery because the saturation curve is rubbish and gets progressively more so the older and hotter they get and there's no voltage regulation. You can get replica C90 single phase reg/recs for about a tenner. They make a big difference to that type of charging system.
Some of the more advanced direct lighting systems have more than one phase, in which case the best bet for running DC only would be to run them all into the battery through an appropriate reg/rec. Enfields do this, they have 2 charging phases and one regulated AC lighting phase but you can bung them all into the battery through a japanese reg/rec if you want to run DC only. I THINK lambrettas have 2 phases, one for charging, one regulated AC for lighting.
In any case, keeping the lighting on a seperate phase when using LEDs is pointless. The more phases going into the reg/rec, the cleaner the charging voltage will be. My diddy batttery will run my headlamp on full beam for 24h. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Triton Thrasher |
Triton Thrasher |
Easy-X |
The last post was made 4 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
