Mod 2 Lifesavers procedure
lazy12
PostPosted: 19:16 - 03 Jul 2019    Post subject: Mod 2 Lifesavers procedure Reply with quote
Need some solid and up to date advice on the lifesaver procedure before my mod 2 so I know what to practice and make habit of before then.
Currently I’m doing as follows,
Turning left - mirrors - left lifesaver - position 1 - right lifesaver - turn
Turning right - mirrors - right lifesaver - position 3 - left lifesaver - turn
T junctions turning right - mirrors - right lifesaver - position 3 - looking left & right - right lifesaver - turn
Am I doing it correctly? Or what’s the current procedure?
NJD
PostPosted: 19:32 - 03 Jul 2019    Post subject: Reply with quote
You seem to think there's a magic formula to pass the test that we're supposed to tell you when in reality the test is there to asses your ability to ride safely. If you've got issues, or confusion, about what checks your supposed to be doing when I'd either bring them up with your instructor or pay someone who can teach you properly.
Can understand checking your mirrors before slowing down to see what's behind you and how close they are; can understand the lifesaver and position change -- since that's what I was taught; can't understand why you'd then be taking your eyes off the corner to check over your shoulder. Sure you'd be checking if anything's cutting you up but you'll be unbalancing the bike half the time and not focusing on where your going.
RAYK47
PostPosted: 08:18 - 04 Jul 2019    Post subject: Reply with quote
I Could be completely wrong here so you should have this chat with your instructor.
There seems to be too many lifesavers for me. Why would you do a right LS for a left turn? If someone is going to turn in on you then they will be approaching from in front. The danger is on your left,
similarly for a right turn, if something comes down your left side it's not a danger (unless they turn right).
Andy_Pagin
PostPosted: 10:31 - 04 Jul 2019    Post subject: Reply with quote
Basically you 'lifesaver' in the direction you're planning to go, it should be instinctive/common sense.
RAYK47
PostPosted: 13:09 - 04 Jul 2019    Post subject: Reply with quote
I think that was what I was trying to say. I don't recall the OP saying how soon his MOD2 was but I am assuming quite soon. If so then he should be pretty up to speed on those aspects and just concentrating on fine tuning etc. If he is not yet comfortable then he needs to discuss with his instructor.
bigdom86
PostPosted: 14:59 - 04 Jul 2019    Post subject: re Reply with quote
too many steps, if you overthink things and don't look confident and wobbly you won't pass, i would do this:
turning left
indicator
check mirror
lifesaver left
move to position
turn left
turning right
indicator
check mirror
lifesaver right
move to position
turn right
CANCEL INDICATORS!
this should be a smooth process and should feel normal you dont even think about it, i find myself doing "lifesavers" simply walking down the road or on my work sites just as it is normal to me to check where im going
Ribenapigeon
PostPosted: 11:04 - 11 Jul 2019    Post subject: Reply with quote
Just wag your head from side to side constantly. Thats all the examiner is seeing anyway so do that and spam the indicator off all the time and you'll be fine.
Teflon-Mike
tl;dr
PostPosted: 17:40 - 11 Jul 2019    Post subject: Reply with quote
Don't confuse a 'Rear Observation' and a 'life-saver'
These days dumbing down to lowest common, of the car driver, rear-obs maybe made in the mirrors, but.. hamming it to make it obvious to following examiner, (who also has to do his own obs whilst watching you) over the shoulder observations are still good form.
Parsing out confusion between rear obs and life-savers:
- rear-obs BEFORE
- Life-Saver DURING
Ie: you do rear obs before you commit to any maneuver, like turning left or right, to plan that maneuver. IF safe.. which depends what you saw on rear obs...
you undertake maneuver... where and when you MAY do a life-saver depends on what you re doing and what is going on.. and you may do more than one.. as you may do more than one rear obs..
EG turning right from major to minor; you would do shoulder check before moving to right of center of lane..... you may then stop before completing the turn, in which case, its effectively 2 maneuvers and you would want to do another rear obs before pulling away and completing.... NOT a life-saver... which you would do as confidence check, DURING the turn, and could be left or and right depending where the hazards were most likely,,,,, you would do a right hand life saver on right hand turn in case of over taking cars or some-one trying to turn inside you,BUT a left hand saver may be prudent depending on road layout if a hazard could be that side, eg at two way intersection.
BUT only if check not intrusive to the rest of the job.. its 'only' a confidence check for changes to situation, its NOT the rear obs,that should have told you what's going on
IE there's no magic formula!! There is no prescription, you need to use oh dear.. 'common sense' and 'good judgement' which is what the testis looking for...... if there was a procedure to follow, then there#'d be little to 'test' wouldn't there?
So, remember Observations BEFORE, Confidence Checks DURING and apply JUDGEMENT
PostPosted: 00:10 - 12 Jul 2019    Post subject: Reply with quote
Wise words Thumbs Up
Ribenapigeon
PostPosted: 21:19 - 12 Jul 2019    Post subject: Reply with quote
You'll learn.
Romance01
PostPosted: 07:44 - 13 Jul 2019    Post subject: Reply with quote
Teflon-Mike wrote:
So, remember Observations BEFORE, transfers reims Confidence Checks DURING and apply JUDGEMENT
you're right
The last post was made 4 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 17 - Page Size: 74.61 Kb
