| brierleystuar... |
 brierleystuar... L Plate Warrior
 Posted: 13:27 - 31 May 2020 Post subject: Kawasaki Er6 rattling noise from engine |
Been out this morning and developed a rattling noise coming from the engine. Happens in neutral and all gears when on throttle. I can't hear it at idle. Ill give my mechanic a bell tomorrow and get it in but interested to see if any of you can advise or recognise what it is. Whilst searching for the issue i also found a significant crack in the downpipe. Seperate issue and im guessing unrelated. The bikes a Kawasaki er6f 2011. 18000 miles. I filmed a video on my phone and you can hear it pretty clearly. File to big to add as attachment on here so uploaded to youtube.
https://youtu.be/f-gVq7iztTA
Thanks for any advice. |
| yen_powell |
 yen_powell World Chat Champion
| brierleystuar... |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| Pigeon |
 Pigeon World Chat Champion
| xX-Alex-Xx |
| brierleystuar... |
| Riejufixing |
 Riejufixing World Chat Champion
| mentalboy |
 mentalboy World Chat Champion
| Pigeon |
| topperuk |
 topperuk L Plate Warrior
| topperuk |
| brierleystuar... |
 Posted: 19:46 - 04 Jun 2020 Post subject: |
| mentalboy wrote: | | Riejufixing wrote: | You are contemplating modular replacement, which may be quite unneccessary.
Sit down and relax - really - with an engine stethescope. Report back. |
| brierleystuartj wrote: | ...Whilst searching for the issue i also found a significant crack in the downpipe. |
Seems like an OK reason to replace the headers, although I might look at getting the crack welded up.
OP: When you say 'second time headers have gone', care to give us a timeframe/mileage covered? I know that there are some right dodgy internet sellers out there but cracked OEM headers are nearly as rare as hen's teeth.
My old Zed had a few alterations which meant that the stock headers were an absolute bastard to fit properly and after one particularly rumbunctious session trying to refit them I cracked a pipe near the header flange - getting it welded in place meant that it held it's new, ever so slight but more than enough, twisty fuck-ed up shape and fitted like a glove when later removed, replaced etc. Could it be that your headers are twisted under a pressure they weren't designed for?
EDIT: I've just remembered that it was the Motad cans that fit differently from the OEM ones and that was what threw out the header alignment.
As for the rattle, it's a Kwak and they were prone to noisy cam chain tensioners. I would hope that they've fixed the old design self-tensioner as those had a tendency to self destruct, as I haven't owned a post-millenium Kwak I couldn't tell you if that is likely to happen.... |
The first time the original headers went was rust rather than a crack near to the join to the muffler. As a temporary but now not so temporary as that was 2 years ago, I had it cut and a new piece of pipe welded. Now the headers have a crack which is at the lowest point of the headers, as they bend towards the back of the bike. I could reuse the muffler but second hand headers are £100 and don't look the best of condition. My original headers and muff are tatty and rusty at joints anyway so not worth welding. I think it's the original exhaust setup and it's done 18000 miles. She's provided me with some good fun so I think she deserves a bit of bling and a new shiny stainless will do the trick.
Im stripping the old exhaust off tomorrow so il investigate the suggestions above regards loose bolts and pegs and report back. If I feel brave I might get a youtube video open on checking the cam chain tensioner and have a tinker with that. |
| brierleystuar... |
 Posted: 15:10 - 05 Jun 2020 Post subject: |
Taken the exhaust off and done another video. It's loud but pretty sure the rattle has gone. The significant crack in the exhaust turned out to be nearly all the way round and hanging on by a thread. This must have been the rattling.
https://youtu.be/c2mNfIIUGGg |
| brierleystuar... |
 Posted: 15:57 - 05 Jun 2020 Post subject: |
This is a video of the headers. The flange for the headers to bolt to the engine has also come off.i suspect this is the actual cause of the rattle. High up where it actually sounded like it was coming from. Case closed but thanks for the replies and help.
https://youtu.be/nbaNMYnkWRM |
| FretGrinder |
 FretGrinder World Chat Champion
| brierleystuar... |
 Posted: 20:09 - 13 Jun 2020 Post subject: |
Good news. The rattle has gone. New stainless steel headers and a high level exit exhaust fitted. Never seen one on an er6 before but I like it.
https://youtu.be/4DUxdVEeBbY |
The last post was made 6 years, 153 days ago. Instead of replying here, would creating a new thread be more useful? |
