Scotch10 |
Scotch10 Borekit Bruiser
jaffa90 |
jaffa90 World Chat Champion
Scotch10 |
Robby |
Robby Dirty Old Man
Posted: 21:34 - 15 Jul 2019 Post subject: |
Two things come to mind.
Rad cap - they can and do fail, so worth replacing.
The hoses to the expansion chamber. Are they set up right, and is the fluid in the bottle at the right level (about half full).
There should be a hose from the rad into the expansion bottle, this hose should poke down into the bottom of the bottle, under the coolant. This is so it can push out some coolant in high temperature/pressure situations, then suck it back in when the pressure drops.
The vent/drain hose from the expansion bottle should not be touching the coolant, and exit from the top.
Also, when you first filled up the coolant to get it all bled out, did you run it up to temp with the rad cap open? You need to do that, the water level in the rad drops when the thermostat opens for the first time, and you top it up. If you try to do it with a closed system you just end up with air pockets and trouble. |
Scotch10 |
jaffa90 |
The last post was made 4 years, 286 days ago. Instead of replying here, would creating a new thread be more useful? |
