RhynoCZ |
RhynoCZ Super Spammer
Posted: 19:05 - 14 Jul 2019 Post subject: Pegaso 650 backfires into the intake... SOLVED! |
What to look for? Valve clearances adjustment done, electrics sorted, carburetors cleaned and having stock jets and setup, no ''visible'' air leaks as far as I can tell, fresh fuel and spark plug...
I'm clueless.
It starts alright but in just a few seconds after that it starts to backfire into the airbox. Then, the engine stalls. Cold/hot does not matter, the engine does run, roughly, if held in high revs. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Easy-X |
Easy-X Super Spammer
WD Forte |
WD Forte World Chat Champion
RhynoCZ |
steve the grease |
Robby |
Robby Dirty Old Man
sickpup |
sickpup Old Timer
RhynoCZ |
sickpup |
sickpup Old Timer
RhynoCZ |
Posted: 16:14 - 17 Jul 2019 Post subject: |
It's the year 2000, the last gen. with carburetors, and it's just not there. A friend of mine just obtained a ''new'' ECU for the bike, so will try that as well.
If the ECU is faulty and the ignition happens too soon or late, it could also, theoretically, cause the issue.
I mean, it's Italian, so it is expected for the electrics to fail, at some point at least. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
sickpup |
sickpup Old Timer
ADSrox0r |
ADSrox0r World Chat Champion
RhynoCZ |
ADSrox0r |
RhynoCZ |
Posted: 09:02 - 20 Jul 2019 Post subject: |
Cleaned and taken apart again for the acetone + compressed air thing. Did not help. It still backfires into the left carburetor. *the left one only
The diaphragms are like brand new, all the seals as well. However there might be one issue, that wouldn't cause this. Many of the o-rings had to be replaced due to deterioration and the new o-rings, although being up to spec, are a bit thicker, as they are not damaged/compressed yet, so when the manual says give it 3,5 turns, the idle jet might not get into the exact same position as it used to. But that alone would not cause such horrid engine running. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Riejufixing |
jaffa90 |
jaffa90 World Chat Champion
RhynoCZ |
Posted: 10:38 - 20 Jul 2019 Post subject: |
The valve clearances are up to spec (checked again) and the crank rotates with no excessive resistance. Maybe, just maybe the intake valve seat on the left hand side is damaged or even the valve itself missing some bits, however the owner refuses to take the head off, at this point.
@Jaffa: It runs an airbox, doing that would not solve the issue, as it's always the left carburetor, that runs like crap. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
jaffa90 |
Sister Sledge |
jimspeed |
jimspeed World Chat Champion
RhynoCZ |
Posted: 14:35 - 24 Jul 2019 Post subject: |
It's fixed now and it was the pressed in jets! More acetone, more cleaning, runs alright now. What a stupid design. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
The last post was made 4 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
