rebeltaz |
rebeltaz Renault 5 Driver
Posted: 06:37 - 30 Jul 2019 Post subject: Vulcan VN1500 Fi Hard to Start When Warm |
I'm not experience in fuel injected engines. My bikes have always been carbureted. This fuel injected VN1500 starts perfectly when cold - pull the choke, spin it over a couple of times and voom. Once I let it warms up, though - after riding it for a while - I can let it sit anywhere from a few minutes to a hour or more and it will spin over for thirty seconds or more before it will finally catch. Throttle open or closed doesn't matter. Once it hits, it's fine.
Could anyone point me in the right direction? ____________________ Derek Tombrello
www.ShelbyCycle.com (for profit)
www.RobotsAndComputers.com (just for fun) |
jaffa90 |
jaffa90 World Chat Champion
Robby |
Robby Dirty Old Man
Grubscrew |
Grubscrew Scooby Slapper
rebeltaz |
Posted: 17:46 - 30 Jul 2019 Post subject: |
jaffa90 wrote: | Can you here a suction noise when releasing the fuel tank cap?
Have you tried the choke (near home) to see if it improves warm starting?
What`s the mileage?
When were the valve clearances last checked? |
Grubscrew wrote: | I had a car do that to me, turned out the valve clearances had closed up once warmed up effectively altering the position at which the valves opened ie too soon. |
No, I don't think the tank is creating a vacuum. I will double check, but... I have tried the choke when it's warm. Doesn't seem to help. The mileage on the odometer reads 11314.
I thought about valves - i haven't checked them since I got this bike - but... I've got an EN450 that had gone through a fire, softening the metal in the head. As you rode it, the valve would embed themselves further into the head, effectively closing the valve clearance. That made it almost imppossibe to start when it was cold, but it started fine when it was hot. I don't hear any valve tap, but I suppose they could still be out of adjustment. I will check that as soon as I get a free spot in my shop.
-=[EDIT]=-
Actually... looking at the service manual just now to see how much I'd need to remove to get to the valves on this bike, I found this:
Code: | Valve Clearance Adjustment
NOTE
○ Since the hydraulic lash adjusters constantly maintain
zero clearance, it is not necessary to inspect or adjust
the valve clearance. |
Sooooo.....
Robby wrote: | What's a fuel injected bike doing with a choke? Has someone stuck a carb on it? |
I don't know, but it does. It's DFI (Digital Fuel Injection) with (what looks like to me) a throttle body. According to the service manual, you shouldn't need to use the choke except in rare instances. ____________________ Derek Tombrello
Easy-X |
Easy-X Super Spammer
Islander |
Islander World Chat Champion
jaffa90 |
Robby |
Robby Dirty Old Man
rebeltaz |
Posted: 18:13 - 31 Jul 2019 Post subject: |
When I got this bike, I had to replace a gasket on the front bevel gear case. Then I had to replace the clutches. When they started slipping again, I had to go back in, with yet another oil change. So that's three times that I have personally replaced that oil - each time with Kawasaki 10w40 oil.
Looking in the service manual again just now, though, - just to make sure I used the right oil for this bike - it shows that this thing is pretty adaptable. For recommended oil type it calls for (SAE10W-40, 10W-50, SAE10W-40 20W-40, or 20W-50).
I'm glad to see that I'm not the only one that this has stumped ____________________ Derek Tombrello
Hong Kong Phooey |
rebeltaz |
jaffa90 |
someone |
someone Two Stroke Sniffer
Hong Kong Phooey |
rebeltaz |
someone |
sickpup |
sickpup Old Timer
rebeltaz |
rebeltaz |
Posted: 18:52 - 07 Aug 2019 Post subject: |
So... no fault codes. Also, the plugs are all running about right - a tad tan, no black or white residue... ____________________ Derek Tombrello
The last post was made 4 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
