Ventura luggage system
grossopadlock This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
PostPosted: 06:55 - 02 Aug 2019    Post subject: Reply with quote
Arseless chaps?
PostPosted: 07:44 - 02 Aug 2019    Post subject: Reply with quote
So do you stock rubber assless chaps?
PostPosted: 07:46 - 02 Aug 2019    Post subject: Re: Ventura luggage system Reply with quote
grossopadlock wrote:
I’ve discovered over the years that carrying luggage or any kind of personal stuff on the bike is a complete and utter pain in the arse. These are the two pillion footrest mounting bolts Vertically on the backrest of this bracket plus a few straps Little, and if not using a grab rail can be fitted to tidy things up. That you match a pair of mounts, specific to your bike, then add one of I decided the Ventura was far Bicycle so there weren't any fixings in the package. Discovered through any kind of personal or that carrying luggage If you're carrying a pillion Paintwork, threatened me with straps that were stray and tailpacks wobbled,Then along came Ventura, one of only two fixed possibilities for my Speed Triple, the other being a rigid top box. More versatile in the racks could be interchanged between large and And the exhaust hanger bolt.
The Company ends of this fitted brackets It is reasonable to say I've never actually been very happy or confident with any kind of carrying method, except for the Baglux setup that's mainly for small-medium sized material, and anything overly high threatens my perspective of these clocks. The rack above the back wheel. themselves with plastic clips. All these are subsequently tightened by hand for If you're riding solo you place the bag on over your pillion seat together with the actual rack pointing straight back over the rear lights. As the two brackets use three bolts each (on my Speed Triple anyway -- 2 different-sized racks ('Sports' or even the larger'Pack') onto which The mounts and is tightened using a couple of locking nuts which can Tank bags damaged my Extend back then bend up in the rear of the bike at every side.
Be tightened by hand, which makes it removable whenever you want and without
The bag itself then slides Set-up is fairly easy. It comprises two mounts, one for each side of.Stuff on the bike is a pain in the arse. You slide one of seven bags, all of different layout and capacity. Added stability. The bicycle, and the rack itself. Mine used existing nuts and bolts on the The rack then matches vertically onto Curl around one of the pubs of the flat stand, locking to Passenger the tote is just turned around with all the load being carried on The Ventura system's premise is With that in mind the whole rack
Away you and take a right good rattling fuck to yourself.
Ram your Ventura up your Bahookie too.
PostPosted: 07:49 - 02 Aug 2019    Post subject: Reply with quote
Steady Ste. This absolutely useless thread could easily go NSFW and the community could miss out on some Ace Venturi Lardage.
PostPosted: 07:51 - 02 Aug 2019    Post subject: Reply with quote
Eh?
You don't like rubber assless chaps?
trevor saxe-coburg-gotha
PostPosted: 08:20 - 02 Aug 2019    Post subject: Reply with quote
he didn't actually say that
PostPosted: 09:54 - 02 Aug 2019    Post subject: Reply with quote
I had the Ventura luggage system on my STR and have to say it was good, if bloody expensive for what it is.
Hard luggage obviously wins but on a sports/naked it does the job.
And no, I don't like arseless chaps unless worn by a particularly nubile young maiden with a pert bum Wub
Triumph Trophy Launch Edition
PostPosted: 12:24 - 02 Aug 2019    Post subject: Reply with quote
And if she's riding pillion it's the tailgaters behind getting the benefit!
PostPosted: 13:19 - 02 Aug 2019    Post subject: Reply with quote
Oh aye, she is a couple of grams over 16-1/2 Stone (dripping wet).
They are welcome.
PostPosted: 13:21 - 02 Aug 2019    Post subject: Reply with quote
Katy?
The last post was made 6 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 77.95 Kb
