Danonymoose |
Danonymoose Derestricted Danger
Posted: 23:55 - 03 Aug 2019 Post subject: Aprilia RS125 carb issues? |
Hi everyone.
I have an Aprilia RS125, 2005 model, full power (derestricted arrow exhaust, modded CDI, powervalve with RAVE unit, Pipercross panel filter).
I'm having real trouble getting the bike to start, and even more trouble getting it to run. The bike starts of its own accord maybe 50 percent of the time. The other 50 percent, I have to use a syringe to inject a couple of millilitres of petrol straight into the barrel before it will start.
When it does start, it struggles to rev past ~5k, and on its way to 5k its very spluttery and weak.
The bike is sparking just fine. I have had the reed system, carb, and air filter out and cleaned thoroughly. The spark plug is oil-fouled, which I believe (and I could well be wrong) is because the bike isn't getting enough fuel? I took the card off again today, gave it a good clean, and put a larger jet in it (140) and my problem persists. I have played with the idle and mixture screws for hours, and have tried the needle on all of it's notches, to no avail. The filter is brand new, as are the reed petals and spark plug. I changed the coil recently as I wanted to be sure that it was sparking correctly, and it is.
I'm at a complete loss as to what to do next! Do I need a 34mm carb? The weird thing is that when I inject petrol straight into the head, I'll get one perfect rev, where the bike will willingly hit the redline if I let it, and then it 'bogs' down again, and won't do it again unless I inject a relatively large amount of fuel directly to the head. I have checked the fuel line, it's free and clear. The float bowl fills with fuel as it should. But even with the 140 (I tried a 145 and it was no better) jet it doesn't want to play ball. The carb had a 120 main jet as standard, and I've tried a 130, 135, 140, and 145 and none of them have helped. I've tried setting the carb back to stock with the 120 main jet and the screws set to around 1 and a half turns out.
Am I missing something? Is it possible that I just have a duff carb?
I've spent the last week reading posts on various forums, especially the ones marked as solved, and nothing seems to have worked for me. I'm new to carbs and 2 strokes. I've had plenty of 4 stroke bikes, and only ever had an issue with a carb on one of them and it was easy. But the carb on my Aprilia is baffling me. I just can't seem to get it working properly. It's a Dell'Orto PHBH28 BD, by the way.
I'm not looking for someone to serve me a solution on a silver platter, but even just a hint as to what could be going wrong would be a godsend. |
Old Git Racing |
Old Git Racing World Chat Champion
Grubscrew |
Grubscrew Scooby Slapper
Posted: 07:48 - 04 Aug 2019 Post subject: |
Return it back to a stock bike. Then you’ll be able to ride it and sell the mods on eBay .
No grief, a rideable bike ____________________ FJR1300/CBR1000F |
Danonymoose |
Robby |
Robby Dirty Old Man
andy_uk |
andy_uk World Chat Champion
Danonymoose |
Danonymoose |
Nobby the Bastard |
Danonymoose |
Posted: 23:32 - 04 Aug 2019 Post subject: |
Nobby the Bastard wrote: | Was it working properly before you changed the plug?
Has it ever worked properly? |
No, the plug change was just to see if it made a difference, which it didn't. I've tried it with the BR10 and the BR9, and there is no perceptible difference.
Yes, it has worked in the past, but that was before the derestricted pipe was put on it. Like I said in my original question, if I inject some fuel into the head, it runs perfectly until it has burned through the fuel. Revs freely. But then it goes back to bogging down, and acts as if it's getting too much fuel, which seems impossible seeing as it had a 120 main jet in the carb when this started, and a 145 makes no difference. |
Easy-X |
Easy-X Super Spammer
Posted: 00:08 - 05 Aug 2019 Post subject: |
Oily spark plug, bogging down, only runs well if you squirt fuel in the carb?
Sounds like it's not getting enough fuel! You've cleaned the carb? Great! Clean it again Also have you pulled the fuel pipe off the carb? Is fuel pissing out of the pipe... basic stuff ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Danonymoose |
Nobby the Bastard |
Danonymoose |
P. |
P. Red Rocket
stevo as b4 |
Danonymoose |
stevo as b4 |
andy_uk |
Danonymoose |
Posted: 19:25 - 05 Aug 2019 Post subject: |
stevo as b4 wrote: | It's a tuning mod, and you need an engine that's already 30bhp+ to even see a tiny benefit from a larger carb, as 28mm can support over 30bhp.
If you're trying to tune an already well modified 125 two stroke to the ragged edge then it's fine, but the std carb isn't a restriction part as long as the slide is opening fully.
But please don't listen to me, better go check with Andy as he seems to know something even the factory doesn't know? |
I'm fairly new to 2 strokes (had one as a kid, always worked fine for the time that I had it) and carbs are pretty new to me, as everything that I've had previously has either worked fine, or been EFI. All I can do is listen to people's advice and weigh it up against what other people are saying.
I'm not trying to tune it to the ragged edge. I'm not even chasing numbers. If it's only making 20bhp that's fine. Right now, I'd just like a bike that runs! The slide opens fully. I've stripped and cleaned the carb multiple times now. It's absolutely spotless clean, and everything (Needle, jets, slide, float, choke etc) is pristine. The only thing I can think is that maybe something isn't sitting quite right, which is why I've bought a new mesh filter for the fuel inlet, and a carb rebuild kit so I can replace all the seals. The reed block is fine, not perished. The reed petals are new, as is the air filter. I've just bought a compression tester, although I'm sure (famous last words, I know) that the compression is fine.
I appreciate any and all advice and help, unless it turns out to be rubbish. Like I said, I'm new to 2 strokes and carbs, so I'm learning as I go, and if someone gives me bad advice and I follow it, at least I'll have learned what not to do next time, right?
Cheers |
P. |
P. Red Rocket
Danonymoose |
P. |
P. Red Rocket
Danonymoose |
Robby |
Robby Dirty Old Man
Posted: 07:59 - 06 Aug 2019 Post subject: |
The reason you're getting lots of tricky questions is because its an RS125. People cock around with them, so there could be a bigger underlying problem.
If the bike is in otherwise good and standard-ish condition, then the only change required should be setting up the fuelling to match the new pipe. A bigger carb is not necessary to make it run right, but may (or may not) be required to get maximum power.
What is necessary is getting the carb set up to match the pipe. Sometimes the pipe comes with recommended carb settings, sometimes you can find it in forums. Either way, if you've gone up from 120 to 145 on the main jet, you should raise the needle height at least one position as well. The needle is really controlling the fuelling between one quarter and three quarters throttle opening.
Of course, it's an RS125, so someone could have messed with it. Common things include messing with the oil pump, disconnecting the autolube entirely and running pre-mix, and poorly done top end rebuilds.
So you want to do a compression check (on wide open throttle), and really make sure that the oiling is working properly. If it is blocked off, disconnected, or has air in the lines, problem.
Finally, if the trouble started just after filling up with petrol, that's a sign that it was running on pre-mix before and you've just trashed your engine. |
The last post was made 4 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
