ThunderGuts |
kgm |
kgm World Chat Champion
ThunderGuts |
Pigeon |
Pigeon World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
mentalboy |
mentalboy World Chat Champion
Posted: 04:57 - 06 Aug 2019 Post subject: |
I ran my ZZR1100 on a split link set up for a short while when I couldn't be arsed to dig out the tools and use the 'proper' link. No kittens were killed. ____________________ Make mine a Corona. |
kgm |
ThunderGuts |
kgm |
ThunderGuts |
Confusion |
Confusion Scooby Slapper
ThunderGuts |
Nobby the Bastard |
Confusion |
ThunderGuts |
Confusion |
ThunderGuts |
Posted: 16:28 - 06 Aug 2019 Post subject: |
Hopefully the spare links will be there when I get home to give it a go. Battery is fully charged on the Aldi knock-off dremel to grind off the pins if I make a mess of it again
Hoping all this reverse psychology (more pins than I need etc.) will mean I'll succeed . . . .
I'll let you know how I get on with the chain - sprockets front and back plus the chain was £71, so chain is probably around £40-ish out of that lot. It's on a hack bike which only churns out 48bhp and spends most of the time commuting so it doesn't really see hard use, although it does go through the winter in all the salt and crud. ____________________ TG. |
Posted: 22:32 - 06 Aug 2019 Post subject: |
Just as an aside. If you're looking for a "budget" chain. I've been running one of those swift chains wemoto are knocking out for a good few thousand miles now with no issues.
If anything, I've had to adjust it less than the OEM EK/regina chains I was using before (I had been buying proper, boxed honda C&S kits off david silvers for much cheapness but they seem to have run out now).
EDIT, I should also say my chain tool has a pin that comes down a hollow shaft to splay the ends of the softlink, never seen one split and the thread is really fine so you tend to just count the turns rather than "feel" because it requires so little force. I usually go for 4-5 turns from making contact. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
ThunderGuts |
Confusion |
jaffa90 |
ThunderGuts |
ThunderGuts |
ThunderGuts |
The last post was made 4 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
