Kneedown1981 |
Kneedown1981 Derestricted Danger
Posted: 09:50 - 06 Aug 2019 Post subject: Spark, compression and fuel but no start |
Hi guys
So as per title really, I have a zx6r f3, bike was running fine, then while sitting idling suddenly started to run on 3 cylinders.
Turned off left for a while and now bike will not start at all.
Removed carbs and cleaned thoroughly, drained fuel, did compression test on all cylinders and they are in spec, plugs are sparking when removed and placed against frame.
Won’t even fire on easy start, turns over fine and plugs get wet but will not ignite. I’m starting to think the spark timing or spark strength is the issue.
My question is will the plugs still spark with a fault on the pickup coil or even the coil pack. Because it went to three I am thinking it’s a possible electrical issue relating to the coil pack and will start testing with the Multimeter.
All safety switches are doing what they should, the shutoff systems On this bike won’t allow the bike to turn over if they are engaged and it turns over fine. However when I crank the engine the tacho needle does not move at all, and from memory it should.
Am also thinking could be a bad ground but want to see what people think and get some ideas.
Thanks for any help guys |
bradh511 |
bradh511 Scooby Slapper
Posted: 09:06 - 10 Aug 2019 Post subject: |
sounds like a spark issue if has comp and wont run on easy start ..
check ht leads are not arking on the top of the cylinder head best done in a dark garage. if not further investigation of coil and cdi unit will be necessary
i doubt to coils would go at the same time unless someone been leaving ingtion on to burn them out. ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 |
BusterGonads |
BusterGonads Trackday Trickster
bikenut |
bikenut World Chat Champion
hawkeyefxr |
hawkeyefxr L Plate Warrior
Robby |
Robby Dirty Old Man
Posted: 22:15 - 21 Aug 2019 Post subject: |
It was running fine - so we can rule out anything mechanical, or a cock-up on a top end rebuild setting the valve timing wrong. I'll rule out compression as well, because it's a 4 and it would be unlikely to lose compression on all 4 cylinders at once.
Fuel is unlikely to be a problem, although if it has a fuel filter I would check/change it just in case. It was running, presumably in regular use, so the carbs are clean. Fuel cleans carbs.
So that leaves electrical. Favourite places for things to go wrong are:
1. Rusty/corroded earthing points. Find them and clean them up. For a quick diagnosis or easy bodge, run a wire from one of the crankcase bolts to the battery negative terminal and see if it starts behaving.
2. Regulator/rectifier, because they are just universally shit and pretty much a service item. Charge the battery. If it then starts, check the voltage of the battery with it running. 14.5V at 4000rpm is good. Less than 13 is bad.
3. Spark plugs, because despite the massive advances in technology and people saying they should last for ages, changing the plugs still seems to solve enough problems to be worth trying. Bikes do work their plugs hard, to be fair.
Try these simple bits before looking for more complex problems. |
The last post was made 4 years, 250 days ago. Instead of replying here, would creating a new thread be more useful? |
