XBR 500 pre-buy check
RhynoCZ
PostPosted: 18:49 - 07 Aug 2019    Post subject: XBR 500 pre-buy check Reply with quote
So, I'm off to see a XBR 500 (33kW) tomorrow. Any particular thing to look for? It's got the RFVC head engine, which I have seen before, but no particular experience with these otherwise.
No need to mention the basics.
Thank you for any info, lads. Thumbs Up
Robby
Dirty Old Man
PostPosted: 21:18 - 07 Aug 2019    Post subject: Reply with quote
Rust in the frame down behind the engine, between the footpegs. Proper rotted-out sort of rust.
virus
PostPosted: 21:20 - 07 Aug 2019    Post subject: Reply with quote
cylinder heads also suffered from cracking between spark plug and valve stems like the CB250rs/xl250 did.
own: 81 xs1100g...
RhynoCZ
PostPosted: 22:23 - 08 Aug 2019    Post subject: Reply with quote
I did check the frame, spotless, couldn't quite check the head, but the engine ran very well, with no oil leaks.
The bike is not flawless, but nothing that I wouldn't be able to fix. The carburetor drain plug leaks, not excesivelly, the charging system does not work, or at least not as well as it should, and I'm gonna have to replace the fork seals.
Other than that, it's a nice clean bike. The previous owner even replaced the fuel tank. I looked inside, with a flashlight and I'll tell you one thing, I have never seen a tank this clean before, and definitely not on a 1987 made motorcycle. The bike is also equiped with the Clubman DID wheels (nice and rare), the gauges work and look good, exhaust are not rusty at all... and so on.
TL; DR: Minor issues, otherwise nice and clean. Oh and the engine is amazing, I haven't had so much fun going ''this slow'' in ages.
I'm gonna share some pictures once I find a bit of time to do so in daylight.
doggone
PostPosted: 07:08 - 09 Aug 2019    Post subject: Reply with quote
The valves are locknut type you can easily do them but need regular checks.
The last post was made 4 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 17 - Page Size: 45.92 Kb
