Suzuki gt125
Alf
PostPosted: 20:23 - 07 Aug 2019    Post subject: Suzuki gt125 Reply with quote
Does anyone know the bearing size for headstock, judging by the cup the top and bottom are different.
I would really appreciate any help as I've inherited several boxes which hopefully will eventually become a bike,
Thanks
A.h.freestone
pepperami
PostPosted: 21:09 - 07 Aug 2019    Post subject: Reply with quote
Robinson’s Foundry are a Suzuki dealer who may be able to help you with parts/information on older Suzuki’s
Or try Crooks Suzuki.
Crooks had the parts for a 1976 TS 250 I was fixing.
Bhud
PostPosted: 21:19 - 07 Aug 2019    Post subject: Reply with quote
Don't pull out either your wallet or your bearing drift or clamps until you've checked, but I think this is the (modern tapered roller replacement) set for the GT125:
https://www.bikeaholics.co/en/ta/8/article/135810/
This (tapered roller bearing) product set is called TOURMAX JMT 7369424
Verify this info first before trying to fit your bearings! I take no responsibility.
The dimensions given on that page are:
Outer Diameter : 45 mm
Inner Diameter : 25 mm
Height : 14.5 mm
Outer Diameter : 48 mm
Inner Diameter : 27 mm
Height : 14 mm
The last post was made 4 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 17 - Page Size: 36.08 Kb
