BusterGonads |
BusterGonads Trackday Trickster
Riejufixing |
Posted: 21:26 - 08 Aug 2019 Post subject: |
Close-up of the fork stanchion/oily ring?
You'll always have some oil on the metal surface, but it shouldn't leak out. If you clean it up, and then pump your 30 pumps, what does it look like? It could be just a bit of an accumulation under the dust seal. If it's just a perceptible ring & no leaky leaks, I would not worry about it. Check the fluid level, just in case, I think it's often worth changing these normally-neglected components.
IF the stanchion isn't visibly pitted, I'd get it MOT'd. Perhaps, if there's any question, wipe it off "just aroud the corner", but it's hard to know.
If the stanchion is pitted, ofc, you might have to think about replacing it. |
Posted: 21:38 - 08 Aug 2019 Post subject: |
I'd pry up the dust seal, pack under it with a sausage of rolled up J-cloth then jam it back down again just before you set off for the MOT...
That trick is as old as fork seals. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Kawasaki Jimbo |
BusterGonads |
BusterGonads |
A100man |
A100man World Chat Champion
Shaft |
Shaft World Chat Champion
Posted: 23:10 - 08 Aug 2019 Post subject: |
Kawasaki Jimbo wrote: | With every bike shop I've ever used you can ask them in advance whether they'd MOT-fail a particular issue and get an honest answer. Ask 'em. I get the idea that it might be leaking slightly due to a lack of use and they might "heal" with use, but still I'd expect to have to renew the seals soon. |
Trouble with that is, not every MOT tester has the same opinion and there are certain parts of the test where they are allowed a little latitude - some take it, some don't.
My view is, a little dirt ring is acceptable, if there is actual moisture on the stanchion or dust seal, it fails, because the next stage is it blows and starts dripping oil down the leg and onto the brake/tyre.
However, I do agree they might sort themselves out with use and you could use Stink's cheat, just don't try the other option and drain the forks to stop them leaking - some moron tried that on me when I failed him for leaking seals (it was running down the legs) then got mightily pissed when I failed the retest because his front end was bouncing like a pogo stick ____________________ Things get better with age; I'm close to being magnificent........
BusterGonads |
Shaft |
Posted: 23:22 - 08 Aug 2019 Post subject: |
BusterGonads wrote: | Shaft wrote: |
However, I do agree they might sort themselves out with use and you could use Stink's cheat, just don't try the other option and drain the forks to stop them leaking - some moron tried that on me when I failed him for leaking seals (it was running down the legs) then got mightily pissed when I failed the retest because his front end was bouncing like a pogo stick |
Excellent thanks. Maybe I should just get the seals and do the bloody job. It's no big deal. Thanks for that helpful post. |
If you're up to the task, for the sake of 16 quid it's not really worth messing about. ____________________ Things get better with age; I'm close to being magnificent........
Kawasaki Jimbo |
Shaft |
Posted: 00:09 - 09 Aug 2019 Post subject: |
Kawasaki Jimbo wrote: | Shaft wrote: |
Trouble with that is, not every MOT tester has the same opinion and there are certain parts of the test where they are allowed a little latitude - some take it, some don't. |
How many testers are there at your average local bike shop? You pitch up, say you'd like to book a test but is this bit likely to pass, or will it need fixing? Him and his mate will take the same view. |
I was just pointing out to the OP that not every tester has the same view and not every tester gets out of bed on the same side every day.
Some parts of the test are cut and dried, pass or fail, no question - this is one of those parts where there is some leeway, which means it could be down to how the tester is feeling that day.
It could also depend on whether the shop do repairs or not, there's nothing like self generating work, but then again, they might not feel like doing yet another set of fork seals this week ____________________ Things get better with age; I'm close to being magnificent........
BusterGonads |
Riejufixing |
Minty |
Minty World Chat Champion
BusterGonads |
Minty |
BusterGonads |
kramdra |
kramdra World Chat Champion
BusterGonads |
Johnnythefox |
Johnnythefox Traffic Copper
BusterGonads |
King29 |
King29 World Chat Champion
kramdra |
BusterGonads |
Posted: 19:56 - 12 Aug 2019 Post subject: |
Passed MOT.
No advisories.
What joy!
Purchase cost £650
Insurance cost £56
Battery cost £25
MOT cost £29
Bike tax £44
Comes out about £800.
Might need a new back tyre. It's a bit skippy on a poor road surface. The Triumph was the same until I changed the rubber. It's definitely the back that is skipping and that tyre is the most worn.
12000 miles, unmolested, engine and bike sweet as a nut. Twenty-two years old, mostly in the garage. What's not to like if you want a cheap runabout?
https://photos.smugmug.com/My-First-Gallery/i-VwC2rmQ/0/d0dd2860/XL/Nighthawk%20at%20Cassies%20-%20Edited%20%281%29-XL.jpg ____________________ 2016 Triumph Street Twin; 2000 Honda CG125; 1997 Honda Nighthawk CB250 |
The last post was made 4 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
