Joshua18 |
Joshua18 L Plate Warrior
Easy-X |
Easy-X Super Spammer
Joshua18 |
Easy-X |
Joshua18 |
BusterGonads |
BusterGonads Trackday Trickster
Monkeywrenche... |
Monkeywrenche... Nearly there...
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 15:40 - 15 Aug 2019 Post subject: |
DO NOT use easy-start/damo-start... stuff is basically ethanol. and it washes the oil off thhr bore so the bore wears out toot-sweet, and the engines become dependent on the stuff as they lose compression.
starterr sounds lazy in vid ; - get the plugf out put a teaspoon of TWO-SROKE oilm or chip fat veggie oil down the plug hole.. leave the plug out, go heck/charge the battery, and whiolst that tops, work the mnotor over on tyhe kicker or a bump NOT trying to start itm just work the opilo into the bo9re where EZ-start has washed it away.
Tjen cleam the guel petcock filter, make sure petrol fresh and petrol tyanbk clean... nd with full chafge in the battery try again... briefly DO NOT run the starter for preolonged periods and wear out the brushes and bearings... if still no go.. sartar ther, recom the starter and solenoid anmd get the motor spining up to full speed on the button... remember NO Etrher and a little vegie oil or 2t down the bore rto luybe rings and stop that wering out and gettinmg te compression up a bit.... 2T nd vbegie WILL burn off when engine fires properly, so be prepared to change the plug when you done, and cleanm the one you got a few rimes whilst farting about.... bey9oind that get the workshjop manual and do #ALL the basic service stuf, itr' oft gets neglected por donme badly, so do it, do it right and be sure the motor s trip-top a it should be before you go looking for problemns like knackered bore or furred up piston rungs that are pronbbabloyt on the cards begg9nb a top emnd rebuilpd now 0or pretrty soon anyway.... your call if you cut t9 the chase and do that now as a precautionary or hope for the best abnd likely do it in a thousand miles or so after lots of effiung.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Ste |
Ste Not Work Safe
Posted: 15:42 - 15 Aug 2019 Post subject: |
The last post was made 4 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
