ThunderGuts |
Posted: 08:39 - 12 Aug 2019 Post subject: Slight whine from new final drive |
So went out for a ride yesterday, about 30 miles, on my fresh sprockets and chain install; thing is, there's a slight whine audible from around 20mph - 50mph (linked to road speed and pulling the clutch has no effect). Really quite faint but it is noticeable (the bike is pretty quiet otherwise); definitely wasn't there before though. Tried going up to similar gears and revs with the bike on the centre stand but couldn't replicate the noise. Bizarrely the noise is more audible with the visor down than up, which makes me think it's being transmitted through the pegs/frame than me hearing it through the air, which could also explain why I couldn't replicate it on the centre stand. Rode through a tunnel too and no difference to noise volume which reinforces the transmitted noise theory I think too.
So, I've checked the tension and we're good, axle is torqued correctly (and I've removed the wheel numerous times before and reinstalled to the same factory torque settings so I don't see that being the issue), alignment is good (measured it axle centre to swingarm pivot centre, less than 1mm difference side to side), sprockets are installed the right way around and the chain and sprockets are all the right size (520).
Things that have changed; sprockets and chain are not the same make/model (previously Kawasaki front sprocket, unknown rear, DID chain, now JT sprockets and chain), front sprocket used to be a rubber cushioned one, now it's a plain steel one.
Tried googling on this and find all sorts of conflicting information, including suggestions the chain is too tight/loose, that it's normal, that it's down to the sprocket change etc etc
It seems unlikely to me I've suddenly got a failing bearing on my hands, it would be quite a coincidence to happen at the same time as a chain/sprocket change, which makes me home in what's changed.
Does anyone have any ideas?
Cheers ____________________ TG. |
Grubscrew |
Grubscrew Scooby Slapper
ThunderGuts |
Riejufixing |
kgm |
kgm World Chat Champion
ThunderGuts |
BusterGonads |
BusterGonads Trackday Trickster
MCN |
MCN Super Spammer
ThunderGuts |
Scythe |
Scythe Crazy Courier
The last post was made 4 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
