Sister Sledge |
Tankie |
Tankie Crazy Courier
Sister Sledge |
Triton Thrasher |
Triton Thrasher Could Be A Chat Bot
stevo as b4 |
Posted: 12:14 - 07 Sep 2019 Post subject: |
You don't need to know the exact true reading based on no volume in the tester or the adapter tube/fittings. It does not matter or make any difference to how your DRZ engine will run if the tester shows - 10psi or so over the quoted book figure. Remember two identical DRZ engines won't likely give the same readings, due to tolerances and other factors.
The compression tester is an indicative diagnostic comparison tool, nothing more. If you have any tester of any level of accuracy, then all that matters is comparison readings of previous test results and the current one over a fair mileage or or running hours interval.
It's the same story with leak down testers, and even endoscopes (the current favourite catch all diagnostic tool). None of them alone used once will tell you how healthy your engine is, and what is wrong with it with total certainty. People these days seem to obsess over diagnosis and what's wrong, rather then periodic engine maintenance and overhaul.
A Moto Gp team doesn't want to faff around measuring compression and leak down or looking down a scope to tell them how good the condition of their engine is, or when to re-build it. They will have logged running hours, and components will be life'd according to the engine design and development team, and the usage conditions and environment. When the stipulated running hours or mileage is achieved, then that motor is coming out regardless.
Bit off topic, but hopefully it shows the insignificance of doing a one time random compression test on a perceived good engine, and worrying about the N'th psi reading and trapped volume in the tester. |
Sister Sledge |
Robby |
Robby Dirty Old Man
stevo as b4 |
Sister Sledge |
Triton Thrasher |
The last post was made 4 years, 229 days ago. Instead of replying here, would creating a new thread be more useful? |
