Charging Issue - Opinions needed
andy_daytona650
PostPosted: 09:22 - 19 Sep 2019    Post subject: Charging Issue - Opinions needed Reply with quote
Hey all
I've had historic charging issues with my Triumph Daytona 650 (2005). An ongoing saga. So just over a year ago I fitted a volt meter to the dashboard so I could keep an eye on it, after I replaced both the regulator and stator.
Last week, the voltage started reducing rapidly from the usual 14.3 volts down to 10 volts and the dials going on/off. My heart sank (for the 3rd time in ownership).
I took the cover off to inspect the stator and yes, once again, the copper has started to soot-up.
I have ordered a replacement stator again but my question is; given that my volt meter display has constantly been recording 14.3 volts right up until it recently started dropping, is it most likely a stator fault as opposed to a regulatory problem? Would value a second opinion.
My logic suggests, given the voltage was not spiraling out of control (regulator issue), the root cause is most likely a poor stator which has over-heated as opposed to a shoddy regulator (another £100 to replace!). I could be wrong?
Cheers, Andy
BMW 310 GS (2019)
PostPosted: 09:59 - 19 Sep 2019    Post subject: Reply with quote
That sounds logical.
I would be inclined to test you stator and reg/rec as per the many vids on you tube. If your stator has gone and reg/rec is ok, carry on using it.
andy_daytona650
PostPosted: 09:51 - 20 Sep 2019    Post subject: Reply with quote
Thanks mate, will check the reg over the weekend and fit the new stator. Appreciate another opinion. A real pain in the a*rse this bike, a love/hate relationship....!
BMW 310 GS (2019)
The last post was made 7 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.43 - MySQL Queries: 14 - Page Size: 36.2 Kb
