unfitforpurpo... |
unfitforpurpo... Derestricted Danger
Easy-X |
Easy-X Super Spammer
Posted: 18:14 - 19 Sep 2019 Post subject: |
What's actually wrong with it? "Non-runner" might just mean it doesn't have wheels
Not starting? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
unfitforpurpo... |
Riejufixing |
Feathers McGraw |
Feathers McGraw Borekit Bruiser
Posted: 21:42 - 19 Sep 2019 Post subject: |
unfitforpurpo... |
Easy-X |
unfitforpurpo... |
Posted: 23:13 - 19 Sep 2019 Post subject: |
You got me, I missed that bad boy off the list, I've got strimmer and chainsaws I can mess about with and get alright carefully carb-wise, but I'm getting a wet plug, and the jets, ports and what have you are all real clean, this evening I did notice the pipe up to the diagram jobby on the tank from.manifold side of carb (I think a vacuum pump, can't remember name) was a little split at the end, but when I've got it cranking I can see fuel moving in the filter, and the float chamber in the carb is getting fuel. To rule.it out and for future reliability I'll put fresh pipe on tomorrow.
I'm not looking to piss on anyone's bonfire, but I feel like I've tried most everything!
I am revisiting where I've been before, so I'll go over that closely again too.
Thanks |
Easy-X |
Posted: 11:11 - 20 Sep 2019 Post subject: |
I was going to say "have you tried taking the air box off and squirting in fuel/easy start directly..." but if you have a wet plug I think fuel is getting in
There's only spark and compression left!
<edit>
Have ya checked the valve clearances ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
unfitforpurpo... |
- Super Spammer
unfitforpurpo... |
unfitforpurpo... |
Posted: 18:08 - 23 Sep 2019 Post subject: |
Ok, so excuses first, for a long time now I've not worked on vehicles that you can bump start or they're fixed engines....
So I bump started it, it was a bit starving down low in the revs, spot on above 4500 or so, and wouldn't idle. I admit I haven't searched it yet, but I've got to go sort animals now, but any tips on setting the carb as much as possible will of course be gratefully received. (Btw Filters clean, not sure how the electric (stop?) works on the diaphragm pump on the tank).
It's a dellorto carb
Idle screw - another screw for mix I guess - and circlip on needle
I'm hoping when it's set-up, at least basically, it will start on the electric start, and I can go from there.
Cheers |
unfitforpurpo... |
Easy-X |
- Super Spammer
unfitforpurpo... |
- Super Spammer
unfitforpurpo... |
unfitforpurpo... |
Easy-X |
Posted: 09:33 - 26 Sep 2019 Post subject: |
Clean the carb again.
Seriously.
A "proper" clean this time
I had three goes at cleaning a carb a while back and it did similar weirdness to what you're describing.
All apart, go over everything with a magnifying glass: get the jets, float pin out, etc. One bit of grit mooching about in there could make all the difference.
If it's still not running well after that THEN you can buy a new carb
Or it's an air leak ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
- Super Spammer
unfitforpurpo... |
Easy-X |
Feathers McGraw |
Posted: 19:58 - 01 Oct 2019 Post subject: |
The last post was made 4 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
