unfitforpurpo... |
unfitforpurpo... Derestricted Danger
Posted: 07:23 - 09 Oct 2019 Post subject: |
Ok, got the new carb, a dellorto phbg.
It was going well same as before, great above 5_6000 rpm, and would idle but with idle screw (not pilot screw) almost right in.
I think I understand it's not the right way to do it, but the needle was on the top notch/clip so I've bring it down to 3 (from top/richer).
It has some pull now at the bottom end and great still up high but when it transitions it's crackling and will slowly die at idle. I haven't pulled the plug yet but it smells rich idling in the workshop and I'm pretty sure there is almost twice as much smoke as there should be from the exhaust.
Also the idle pilot screw makes little to no difference.
I'm after a bit of advice as I'm thinking to rip it all apart and put new gaskets and seals right through it, but guess I'll still have to tune the carb?
I know I'm capable and have the gist of what's going on but don't have the experience of petrols and 2 strokes to see the pointers intuitively |
- Super Spammer
Feathers McGraw |
Feathers McGraw Borekit Bruiser
Easy-X |
Easy-X Super Spammer
unfitforpurpo... |
redeem ouzzer |
Easy-X |
unfitforpurpo... |
unfitforpurpo... |
Posted: 23:41 - 15 Oct 2019 Post subject: CELEBRATE |
Ok, finally! Some positive noises.
I ordered a 50cc piston and barrel, and fitted it tonight, thought I could get away with doing it in the frame, but halfway through changed my mind. I know I was being proper lazy, but...
All done and tried bump starting it.....
Then I put fuel in.... and away we go. Hooked the jump pack up to the battery, and only takes 1 revolution and shes purring.
I literally have not touched the carb yet since starting it, I put the needle back to the top notch (lean) before I put the barrel back in but that's all I've done to that.
I will take it out for a ride tomorrow morning and see how it pulls, what adjustment etc it may need.
I guess the 70cc kit that had been fitted to it just didn't agree. I took the previous owner at his word that it was running fine and just started playing up (seemed like a decent bloke).
I'm happier with running it at 50cc anyway for my lad as it was quite pokey for what it was when you hit the right rev ranges.
Thanks very much to you all for your help, and I hope that your advice here will help someone else in the future.
Heres hoping tomorrow goes straightforward.
[/b] |
The last post was made 4 years, 187 days ago. Instead of replying here, would creating a new thread be more useful? |
