Kawasaki kxf250 problem need advice !
ValentinoRoss...
PostPosted: 21:00 - 14 Oct 2019    Post subject: Kawasaki kxf250 problem need advice ! Reply with quote
Hi people just bought a kxf250 4stroke was running goid when i first got it only problem i have now is that when i push the choke back in the bike cuts out unless you give it revs this can happen even if you are actually riding did some research on it and it came up that its probably the air. Fuel mixture screw checked my carb and i couldn't find none there so am guessing it may have fell out or it doesn't require one...2nd issue is that i stupidly put 10w40 car oil in in my engine and now and it came out off the breather pipe quite alot of it so am guessing i overflowed it ? Will this car engine oil seize or destroy the bike or cause it to overheat because im now seeing a glowing red on the exhaust se manifold in the first 60secs of the bike being on???Im new to bikes please help? Is everything related to the air mixture screw or the wrong oil? any Advice will help Thanks!!!
Riejufixing
PostPosted: 21:08 - 14 Oct 2019    Post subject: Reply with quote
If you do 't k oe about bikes, I should find your nearest bike shop that does maintenance and take it there, preferably by van.
Kentol750
PostPosted: 23:28 - 14 Oct 2019    Post subject: Reply with quote
In a van, definitely take it there in a van.
Some bikes.
The last post was made 6 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.39 Sec - Server Load: 2.98 - MySQL Queries: 14 - Page Size: 34.49 Kb
