 TheGazWaz Nitrous Nuisance
 johnsmith222 World Chat Champion
 Posted: 22:31 - 25 Sep 2019 Post subject: |
I've not done the headstock bearing on my 9R, but have had most of the front end off it.
I'd imagine it would be pretty similar to your gsxr.
Unfortunately as I've got a stand similar to the Abba stand, then I just used this and put some weights on the rear of the bike to lift the front. I had backup ratchet straps on the front too.
I'm not sure I'd fancy doing it without an abba stand or similar tbh.
I can't forsee any difficulties taking the steering yokes off and replacing the bearings. Everything else before that was fine for me.
On an unrelated note, what sort of crash bungs do you have on the bike? The kind that bolt on to the fairing fitting are notoriously useless and can smash a hole in your engine:
https://i.ebayimg.com/images/g/vboAAOSwyZ5Upnnj/s-l300.jpg
You likely know this already, but just in case you're not aware.
The bexmoto or r and g ones are the ones to get if you don't have them already. Otherwise I'd go without. |
 trevor saxe-coburg-gotha World Chat Champion
 Posted: 08:46 - 26 Sep 2019 Post subject: |
On the dedicated zx9r forum the advice is often to turn the bearings so that the weight and force is then focused on a non-worn part of the bearing, as opposed to replacing them.
There are various threads on the topic @ zx9r.net because it's such a common occurrence. I've had them notch twice now, and in fact, my bike's steering was like that when I bought it w/ 18k on it. And what's more, I'd guess they'd been going since 15k. In other words, be prepared to work on them, if not replace them, every 15k or certainly every 20k.
Not sure why the bike suffers this way, but I did wonder if it's at least partly because of it's rake/trail/offset i.e. geometry. On the plus side, there's never any need to fit a steering damper of any kind (mechanical or hydraulic) - otoh, the angles seem to eat bearings. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
