Kawasaki VN1500 Meanstreak Gears
iHulk80
PostPosted: 12:55 - 26 Sep 2019    Post subject: Kawasaki VN1500 Meanstreak Gears Reply with quote
Hi,
I'm having some problems with my gears on my bike not springing back into the home position after selecting gears, i have to manually return the gear lever with my foot again before i can select a new gear.
Any help / advice would be greatly appreciated,
Thanks in Advance.
PostPosted: 14:31 - 26 Sep 2019    Post subject: Re: Kawasaki VN1500 Meanstreak Gears Reply with quote
Does it use a linkage between the lever and the selector shaft on the gearbox?
If so; clean out the linkage (a good bit of WD40 sprayed in and a wiggle should do it).
Make sure you re-lube it after at some point; maybe with a PTFE spray or similar.
The last post was made 5 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.8 - MySQL Queries: 13 - Page Size: 30.46 Kb
