Aprilia MX125 won't spark
WheelieKid
PostPosted: 19:53 - 31 Jan 2020    Post subject: Aprilia MX125 won't spark Reply with quote
I have recently rebuilt the top end on an aprilia mx125 with a rotax 122 engine. However when I went to start it it wouldn't start.
The bike needed a top end rebuild as it cut out while driving as the piston rings seized inside the grooves (oil pump failed so wasn't lubricated).
Before the top end rebuild it did have a spark despite the engine not wanting to start. It also has fuel (cleaned the carb to make sure it wasn't that) and compression. The electrics seem to work as the lights turn on.
At first I thought it was timing but I have read the manual and it says that there is no provision for checking ignition timing on a rotax 122 engine.
Anyone know how to adjust the timing or if the problem is somewhere else?
A̶p̶r̶i̶l̶i̶a̶ ̶M̶X̶1̶2̶5̶ Honda CG125
jaffa90
PostPosted: 22:52 - 31 Jan 2020    Post subject: Reply with quote
Can only think of safety cut out switches that kill the spark, have you a voltage reading going to the coil when the engine turns over?
WheelieKid
PostPosted: 09:40 - 01 Feb 2020    Post subject: Reply with quote
I'll check voltage to the coil today. What do you mean safety cut out switches? Do you mean where the connection is grounded through the kickstand or something else?
jaffa90
PostPosted: 11:32 - 01 Feb 2020    Post subject: Reply with quote
Side stand switch, clutch switch, neutral switch, tilt switch.
All bike models differ.
WheelieKid
PostPosted: 19:06 - 01 Feb 2020    Post subject: Reply with quote
Oh okay I see I will check those. However I believe the problem is a faulty wire between the ICU and the coil as I tested it's continuity twice, the first time there was continuity and the second time there wasn't. Any idea of what gauge wire I should use?
jaffa90
PostPosted: 22:02 - 01 Feb 2020    Post subject: Reply with quote
I`ll rephrase, have you a pulse voltage going to the coil when the engine turns over?
The last post was made 6 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.7 - MySQL Queries: 14 - Page Size: 46.87 Kb
