Riejufixing |
Nobby the Bastard |
RhynoCZ |
RhynoCZ Super Spammer
WD Forte |
WD Forte World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
Sister Sledge |
colink98 |
colink98 Could Be A Chat Bot
Posted: 11:46 - 19 Oct 2019 Post subject: |
The heat from the soldering heat hardens the steel cable making it brittle. Solder wicking down the cable creates a stress riser directly below where the solder comes to.
Sometimes an aggressive flux which hasn't been neutralised will also cause corrosion.
If a cable is going to break, that is where it will break.
I bet if you look closely, the cable sticking out of the nipple will be soldered down to where it broke. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
vitus detritus |
vitus detritus Derestricted Danger
Riejufixing |
Riejufixing |
Riejufixing |
Sister Sledge |
Riejufixing |
Posted: 13:32 - 20 Oct 2019 Post subject: |
Sister Sledge wrote: | As stinkwheel says - heat? How much heat are you using? What are you using as a solder to fix the nipple on?
I ask because that's a type of high tensile wire and heat alters the properties of it - it could well be making the wire brittle or perhaps turning it 'soft'. |
It has been said: "The heat from the soldering heat hardens the steel cable making it brittle". In fact, it makes the strands of the cable a lot softer, as you say. It can easily be seen: get a piece of inner cable, and heat it. Let it cool in air. Bend it. Try a file on it. You will see what's happened. Now, re. solder, yes it can run into the cable, but that simply moves any concentration of stress along the cable. In this case, the cable should not be bending where it exits the nipple, cos that bit's unmoving in the groove in the assembly. I think the problem's possibly that the inner binds in the outer, leading to bending near the nipple when the twistgrip's closed. Again, an original cable failed in this way, followed by the replacement made up at home.
For soldering, I'm using lead-free plumbers' solder (melts at ~228C, a bit higher than 60/40 which is ~190C. I'm using the smallest nozzle I've got with propane (and only the outer cone of the flame), careflly, with La-Co flux, heating the solder as well as the nipple wken applying. The cable is bicycle-shop gear cable (enough for two cables, £1.40!). |
Riejufixing |
Sister Sledge |
Triton Thrasher |
Triton Thrasher Could Be A Chat Bot
Posted: 16:53 - 20 Oct 2019 Post subject: |
When you get onto properly big ones, not like that piddly stuff you have there, they use crimps. They used to have up to 250 tonne wire rope slings at my Dads lifting equipment company. The white metal was swaged on with a hydraulic press and a form. Wire rope the thickness of your arm.
The scary thing was when they proof-loaded them in a hydraulic test bed. One broke once, cut most of the way through an RSJ. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 4 years, 189 days ago. Instead of replying here, would creating a new thread be more useful? |
