SV1000S Fi warning light.
Irezumi
PostPosted: 13:00 - 26 Jun 2021    Post subject: SV1000S Fi warning light. Reply with quote
Quick history, exhaust leak from join between rear header and collector, purchased new graphite gaskets. Also did valve clearances, oil and coolant + spark plugs for a full service. Put bike back together and started, running great, FI light comes on. I switch the bike off and realise the O2 sensor wasn't connected.
Re-connect the wire but the FI light wont go out after restart and when getting the Suzuki code up its comes up as C44, which is 'heated oxygen sensor'. Bar changing the sensor is there anything else I can do. Is the Suzuki ECU of this area smart enough to have a memory therefore will unplugging the battery for a while help?
I've ridden the bike for approx 5 miles and after this it came back on soon after restarting. Bike itself runs great!
xX-Alex-Xx
PostPosted: 13:05 - 26 Jun 2021    Post subject: Reply with quote
Try disconnecting the battery for a few hours. Worked on my K5 at least when I did something similar.
DILLIGAF
Tdibs
PostPosted: 16:10 - 29 Jun 2021    Post subject: Reply with quote
Would chance trying suzuki dealer to clear codes with their diagnostic tool. Then start swapping parts if that fails to clear the code.
PostPosted: 17:32 - 29 Jun 2021    Post subject: Reply with quote
Suzuki codes clear when you turn off the ignition.
Find the dealermode plug it will have a rubber cap and two small wires. Make it accessible when the ignition is on. Run the bike until you get the FI light up then stop the engine but leave the ignition on.
Short the two pins in the dealermode plug and the fault code will appear on the display. A paperclip will do it.
Irezumi
PostPosted: 21:16 - 07 Jul 2021    Post subject: Reply with quote
Had done this to locate it to the lambda sensor, code C44 is coming up. Test of sensor shows it is the problem. Anyone know where to get replacements that dont cost the £300 odd of the OE item?
xX-Alex-Xx
PostPosted: 21:58 - 07 Jul 2021    Post subject: Reply with quote
Just buy an eliminator and a plug for the sensor hole in the exhaust.
https://www.ebay.co.uk/itm/194165761373
DILLIGAF
PostPosted: 22:50 - 07 Jul 2021    Post subject: Reply with quote
OE Suzuki sensor is just a shitty 3-wire narrowband sensor IIRC don't pay £300 get a 3-wire, a used one if you like.
Or spend the 13 quid on that eliminator Alex linked to.
Fisty
PostPosted: 19:49 - 08 Jul 2021    Post subject: Reply with quote
Had the same on the Busa, use an eliminator.
Fatter and faster than Fret
Irezumi
PostPosted: 21:16 - 08 Jul 2021    Post subject: Reply with quote
Its a 4 wire on the sv. Thanks for the advice, will get the elimination kit.
carbon90
PostPosted: 04:04 - 26 Jul 2021    Post subject: Reply with quote
We will try that as well. A buddy of mine recently acquired this SC1000S with the same FI issue and has been sitting for more than a year now. Got to finish installing the bumper and winch on the Ford truck before we can clear the garage.
PostPosted: 06:24 - 26 Jul 2021    Post subject: Reply with quote
Do you find that having the FI light n gives you an early rev limit? It's been a long while since I messed with Suzuki ECU's but I seem to remember the FI light be ing on invokes the neutral map which kicks the soft limiter in early. For sure wiring the clutch switch permanently closed does it.
Irezumi
PostPosted: 19:21 - 27 Jul 2021    Post subject: Reply with quote
No, did not find there was any limitation to revs. Bike ran fine apart from the FI light.
Have fitted the eliminator plug, however the sensor is well and truly stuck in the exhaust. Tried penetrating fluid and heat. Decided it was most likely going to damage the exhaust the way it was going so just cut the wire and left in situ.
Bike works fine as is, although could do with TB's balancing.
steve the grease
PostPosted: 20:03 - 28 Jul 2021    Post subject: Reply with quote
An eliminator doesn't really sort the problem , fuelling will be all over the place. Give these guys a ring- they sell loads of different Lambdas
https://www.gendan.co.uk/
If it's a generic 3 wire then they will sell them.
https://www.gendan.co.uk/product_O23WIRE.html
The last post was made 4 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 10.04 - MySQL Queries: 14 - Page Size: 77.72 Kb
