Prottecttor |
Prottecttor L Plate Warrior
- Super Spammer
Prottecttor |
- Super Spammer
Prottecttor |
Posted: 12:15 - 10 Nov 2019 Post subject: |
I have checked, plenty of pressure on the thumb. Spark plug is getting wet, there is a spark yet the bike still does not start i Will mention that the wire from servo is not really connected to anything. |
- Super Spammer
Posted: 12:21 - 10 Nov 2019 Post subject: |
Prottecttor wrote: | I have checked, plenty of pressure on the thumb. Spark plug is getting wet, there is a spark yet the bike still does not start i Will mention that the wire from servo is not really connected to anything. |
If it has fuel and spark, then you need to properly test the compression. If you still refuse to do that, at least take the exhaust off and shine a torch up the exhaust port to see if there's any visible damage to the piston or rings
The power valve servo not being connected won't stop it from running. Most are restricted and disabled with a jumper in the electric box to the left of the barrel, in the UK anyway. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
Prottecttor |
- Super Spammer
Easy-X |
Easy-X Super Spammer
bikenut |
bikenut World Chat Champion
Posted: 14:21 - 15 Nov 2019 Post subject: electrics |
Get a wiring diagram, and a multi meter suitable for 12volt stuff. The meter need not be an expensive one, say £15 or less to do the sort of stuff you need to do on this and other bikes. If you dont have a multi meter ask santa for one early!
Once you have the wiring diagram, just interest your self with the wires to do with the ign circuits.
Find out what the timing marks are on the flywheel, and check ( check dont assume ) that the piston is at TDC when the flywheel says it should be ( sheared flywheel woodruff key possibly, rule that in/out first ) at TDC.
Its a question of ruling stuff out one by one for you, others, with the bike in front of them, could drop on the fault in 10 seconds flat, or it could take you days/weeks/months.
get a WIRING DIAGRAM and be methodical.
As a matter of interest, do any lights like the neutral light "flash" when steering turned lock to lock? ____________________ nuts about bikes |
The last post was made 4 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
