slowside |
slowside Nova Slayer
Nobby the Bastard |
Polarbear |
Polarbear Super Spammer
Posted: 00:58 - 13 Nov 2019 Post subject: |
It's quiet amazing how much crap can sometimes be found in a brake system. Also brake fluid is hygroscopic so older fluid can have contamination. Edited to add - use brake fluid from a new, unopened can for this reason.
Give everything a good clean then use new fluid and do a flush before bleeding. You only do this job once in a blue moon, do it properly. ____________________ Triumph Trophy Launch Edition |
Pete. |
Pete. Super Spammer
Posted: 11:17 - 13 Nov 2019 Post subject: |
I would pump it out through the nipple until the reservoir is just about empty then push the pistons back in and pump it again then once the fluid level is just at the bottom of the reservoir top it up and pump new fluid through until it's coming out clean. If you do it right you'll get out nearly all the old fluid with no need to bleed air bubbles which can be a real bind on some bikes. ____________________ a.k.a 'Geri'
Pete. |
Pete. Super Spammer
slowside |
Nobby the Bastard |
slowside |
Grubscrew |
Grubscrew Scooby Slapper
The last post was made 4 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
