JackButler |
JackButler Traffic Copper
Bhud |
Bhud World Chat Champion
Posted: 15:40 - 14 Nov 2019 Post subject: |
What's in it? That's a good question. I don't know.
I used to have problems with fuel even from proper petrol stations, but it wasn't gunking, just water/silt from, presumably, fuel that had been sitting in their forecourt tank. Nowadays I don't have any issues, but I only ever buy the more pricey option at the pump.
When you get an old project bike, there is usually lots of green gunk in the fuel system that you need to clean out. It's commonly called varnishing, and I've heard that it's a result not of petrol but of petrol stabilising (evaporation-limiting) additives. I'm not sure whether that's accurate, but it seems to make sense. In theory, and this is just what I have heard, you should not be getting varnishing at all with the addition of ethanol. Ethanol may cause other problems, dissolving rubber parts and binding with water, but it shouldn't cause additional green gunk varnishing because it evaporates.
The composition of modern petrol is of interest to everyone who runs carbs, and I'd like to learn more about it. |
JackButler |
MarJay |
MarJay But it's British!
JackButler |
Easy-X |
Easy-X Super Spammer
MarJay |
Posted: 18:27 - 14 Nov 2019 Post subject: |
That green shit is corrosion. Brass is a copper/zinc alloy. It's very stable but it will corrode if exposed to air and moisture. Probably caused by the bike sitting unused for a protracted period with a little moisture in the float bowl. Usually accompanied by lots of white furry shit on the inside of the float bowl too. Ethanol wont be helping in terms of moisture sinking to the bottom over a longer period.
If you've got an older bike that isn't "ethanol safe" you can add a shot of stabiliser to the fuel when you fill up. I'm using one called ethomix in my '91 VFR750.
If it's going to be parked up for a while you should run stabilised fuel through it or drain the float bowls (either with the drain screw or by turning off the petrol just before you pull in and letting it run out before killing the engine). Brim the tank with stabilised fuel too to stop the inside rusting. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
slowside |
slowside Nova Slayer
MarJay |
xX-Alex-Xx |
Nobby the Bastard |
MarJay |
redeem ouzzer |
steve the grease |
weasley |
weasley World Chat Champion
JackButler |
redeem ouzzer |
MCN |
MCN Super Spammer
stevo as b4 |
redeem ouzzer |
UncleFester |
JackButler |
Sister Sledge |
The last post was made 4 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
