piratebiker |
piratebiker Derestricted Danger
Posted: 10:21 - 19 Nov 2019 Post subject: |
That's an overflow. Either your needle valve is damaged/dirty/blocked or the float is punctured.
Hitchcocks do a service kit for those carbs. They are a mikcarb, a licenced copy of a mikuni. The kit has all new brass parts and seals up to mikuni spec. They improve the running of even a new mikcarb (especially at idle) and yours is 25 years old. The kit includes a new needle valve and seat.
I'd suggests stripping and cleaning the carb and fitting a service kit.
Also check the float. If it has fluid in it (shake it next to your ear) or sinks/floats unevenly on water, it's burst and needs replacing.
If you have a performance exhaust/air filter, you may have different jetting on your carb so check what's in there as you strip it, they should have numbers stamped on them.
I would be the last person to suggest using kitchen equipment for motorcycle parts however, if you strip the carb, the body and float bowl will come up lovely after a run through the dishwasher.
If you're short on funds, try cleaning the needle and seat and check the float but I'd budget for replacing the needle valve and seat. The needle has a rubber ring on it which may not have been ethanol proof in 1994, a new one will have a viton sealing ring.
https://accessories.hitchcocksmotorcycles.com/1837?qty=1&continue_url=https%3A%2F%2Fwww.hitchcocksmotorcycles.com%2Fpartsbook-pages%2F1621 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
piratebiker |
piratebiker |
Polarbear |
Polarbear Super Spammer
Posted: 12:22 - 10 Dec 2019 Post subject: |
Posted: 13:51 - 10 Dec 2019 Post subject: |
You wouldn't normally remove the overflow. It'll be attached to a pipe on the inside of the carb and is almost certainly a very tight push-fit. The plastic bit may well be glued on.
The overflow isn't a valve, it's just a pipe in the bottom of the carb. If the fuel level gets too high, it reaches the top of the pipe and fuel runs out of it. Exactly like the overflow on a toilet cistern Nothing there to go-wrong and there should be no need to remove it.
You need to fix the reason stuff is coming out of it which will be something in and around the vicinity of the float or needle valve as previously discussed. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
WD Forte |
WD Forte World Chat Champion
The last post was made 4 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
