Scotch10 |
Scotch10 Borekit Bruiser
- Super Spammer
Posted: 10:11 - 22 Nov 2019 Post subject: |
Me too, if the switch, thermostat, wiring and fan is OK.
Clearly, at least one of those can't be fully OK.
The thermostat may open in hot water, but does it provide an electrical contact at the switch (edit - realised this is separate)? Are the meter readings correct?
Even with a non working fan though, should it be boiling? Is the water pump actually working?
I'd but one of those cheapie Ebay infared thermometer guns. You can then point them at varying parts, making sure you have flow around the cooling system. For £7 everyone should have one.
https://www.ebay.co.uk/itm/Digital-Non-Contact-IR-Infrared-Thermometer-Laser-Temperature-Gun/202726498616?_trkparms=ispr%3D1&hash=item2f3370e138:g:O-gAAOSw9m5cRome&enc=AQAEAAACUBPxNw%2BVj6nta7CKEs3N0qWdPFwh%2FxtOAE1NArX3yAwW%2FlhIhCyjHbhgGWsYm6YR77RQq79JTko8iRXHn9GO43mdyok06pyvCUYUAFrdJerUpD3cDyuzhR8BMuZHBnm8Loez4%2FPE7kRUgq5PxpmFk9VdhZfpmMYi%2FEwEa9bhdcaNOEaZF%2Bhxc43R8HA6beQIGYp2bpcflOOaJjRXYYhU%2F2XVz6IeYdrMLHvErRRTWfWHuEVd5J8WyZt1oW3LWOz%2FFasC4SyutYNJrKPnuQyqxcoanhhe3Lc1ECjzRZUBQBiyo%2BwvB0o%2BvyXrJh26ZbmIF8TtUa6fLBCp5DY%2BUvPc0elfmECURmOqzJqABtxFxzJCnbHiELvryk7SMb1r8cixPK7Ch6lNEisuKIyKz%2BgdkQyWNH5NDmQv363AjilCYXRT%2Fh%2Bkzc3ia%2BwDXfkZgEPyG1M4L0jek872Jn6WMVdQ3qKmZzThPondECDvWOoFTrA83rkiBTSCQ8rAFOzWvfAD3rJssQ4VrJ1S%2BPXvEBoK6i%2F9EGrPmz5locI6x9SbG7bvRl4P8qnpSFs5FimSF%2BS0M8sG5z9gubi2k2iQl0L0%2FL9CAVL8ydRu%2BdSJt%2FC0j%2FnnePDLy5jASn00t%2B8qtD6cxfrfNwLcZwBWVLdVobG911PUKl0y2foHL3r4RpgxEgJYrbkejIdre0aJkdeT51IHvm64Rgo0TUNMj56%2FRmLaeaEotfuiNVbPBt3idQKDPucS8BnQVUqadCPLCmClUvAgXFKCYozdkQfvkHnZSpP%2FVwY%3D&checksum=2027264986169f86a80e6b894564b5ff7c735cfb337f&enc=AQAEAAACUBPxNw%2BVj6nta7CKEs3N0qWdPFwh%2FxtOAE1NArX3yAwW%2FlhIhCyjHbhgGWsYm6YR77RQq79JTko8iRXHn9GO43mdyok06pyvCUYUAFrdJerUpD3cDyuzhR8BMuZHBnm8Loez4%2FPE7kRUgq5PxpmFk9VdhZfpmMYi%2FEwEa9bhdcaNOEaZF%2Bhxc43R8HA6beQIGYp2bpcflOOaJjRXYYhU%2F2XVz6IeYdrMLHvErRRTWfWHuEVd5J8WyZt1oW3LWOz%2FFasC4SyutYNJrKPnuQyqxcoanhhe3Lc1ECjzRZUBQBiyo%2BwvB0o%2BvyXrJh26ZbmIF8TtUa6fLBCp5DY%2BUvPc0elfmECURmOqzJqABtxFxzJCnbHiELvryk7SMb1r8cixPK7Ch6lNEisuKIyKz%2BgdkQyWNH5NDmQv363AjilCYXRT%2Fh%2Bkzc3ia%2BwDXfkZgEPyG1M4L0jek872Jn6WMVdQ3qKmZzThPondECDvWOoFTrA83rkiBTSCQ8rAFOzWvfAD3rJssQ4VrJ1S%2BPXvEBoK6i%2F9EGrPmz5locI6x9SbG7bvRl4P8qnpSFs5FimSF%2BS0M8sG5z9gubi2k2iQl0L0%2FL9CAVL8ydRu%2BdSJt%2FC0j%2FnnePDLy5jASn00t%2B8qtD6cxfrfNwLcZwBWVLdVobG911PUKl0y2foHL3r4RpgxEgJYrbkejIdre0aJkdeT51IHvm64Rgo0TUNMj56%2FRmLaeaEotfuiNVbPBt3idQKDPucS8BnQVUqadCPLCmClUvAgXFKCYozdkQfvkHnZSpP%2FVwY%3D&checksum=2027264986169f86a80e6b894564b5ff7c735cfb337f ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG.
Scotch10 |
davebike |
davebike World Chat Champion
Posted: 12:00 - 22 Nov 2019 Post subject: |
If you got liquid (coolant I hope ) rushing out if you run the engine with the pressure cap off you probably have a blown head gasket compression to coolant Get it compression and "sniff" tested (sniff test looks fro hydrocarbons in the coolant ) ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
Scotch10 |
davebike |
Posted: 12:14 - 22 Nov 2019 Post subject: |
OK so if it only spues coolant when revved head gasket may be ok
So fan works if you put 12v across it ? Not stuck?
Fan switch provided earth ?
You have 12 the fan ?
there is plenty of coolant in the system fan switch will not work if not in coolant ! ____________________ Dave
Scotch10 |
davebike |
Posted: 12:27 - 22 Nov 2019 Post subject: |
YES BUT
Check the fan works when you use separate wires to connect it to the battery i.e. test it
is there 12v getting to the fan connector
is the fan switch actually providing earth when the bike is hot
is the body of the switch connected to earth?
changing bits at random sometimes works doing diagnosis just works ! YOU do have a multimeter don't you??? ____________________ Dave
Scotch10 |
MCN |
MCN Super Spammer
Scotch10 |
- Super Spammer
Scotch10 |
Monkeywrenche... |
Monkeywrenche... Nearly there...
Scotch10 |
- Super Spammer
Scotch10 |
Robby |
Robby Dirty Old Man
Posted: 15:55 - 22 Nov 2019 Post subject: |
A few bits seem off.
You mention steam coming out of the expansion bottle. The expansion bottle should have coolant in it up to the line, and the pipe from rad to bottle should be at the bottom of the bottle. This means that any steam coming from the rad is spat out into the bottom of a bottle full of liquid, and should condense back to liquid before it gets out the top of the bottle.
So check your pipe routing.
Next up in radiator cap. If that isn't working, then it isn't letting the system pressurise. This means the coolant is boiling at ~100 degress, rather than ~115. New rad cap is worthwhile.
Finally, it could just be air in the system or a pig to bleed. So before fiddling with it too much, do the following:
1. Change the rad cap.
2. Check the routing of the pipes, to make sure the pipe from the rad to the expansion tank exits at the bottom of the tank.
3. Make sure the system is filled up, and the expansion tank has coolant in it up to the line.
Then run the bike up to temperature, turn it off, and walk away for at least an hour. If the level in the expansion bottle has dropped, it had air in the system which is now replaced with coolant. Refill the bottle, do the same thing again.
Only once you are sure that the system is full and working properly should you start looking at the fan switch and its associated wiring. You can test them in a pan of hot water. If the wiring is done well, the fan switch is probably used to trigger a relay, which powers the fan - so check/change that relay. You could even run it as a whole new independent circuit off the battery. It will only draw power when the engine is very hot, so it won't flatten your battery just sitting there wired into the battery. |
Scotch10 |
Sister Sledge |
Scotch10 |
The last post was made 4 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
